Question about Microwave Ovens
Failed Magnetron I have a Panasonic NN-D851 with its Magnetron failed, anyone know where I could get a replacement? The label has been partially removed and the only number on it is: 36AT66572.
  • dave_canterb Jun 03, 2009
    Hi
    I had already tried that and unfortunately Panasonic no longer list my model number NN-D851.
    President:
  • 1,185 Answers
Posted on Jun 02, 2009
  • Tom
    Tom Jun 03, 2009
    As a lot of the magnatrons are generic parts made by some factory in Asia who turn them out like by the million it is more than likely that they are fitted to other makers machines.
    It is worth stripping down the unit and read who actually made it for Panasonic and do a quick check on their web site
Panasonic Dimension 4 Genius problem
An internal fuse may have blown or the magnetron may have failed
Apr 09, 2013 | Panasonic Genius Prestige Nnsd997s -...
H98 ERROR CODE ON A PANASONIC M/W NN-SN797S WHAT DOES THE ERROR CODE MEAN?
H98 means that the magnetron or invertor has failed. The invertor is not user serviceable.
Mar 10, 2011 | Panasonic Microwave Ovens
Panasonic microwave S333 just stopped suddenly. I see on the internet that this has happened to others after about 2 yrs use. Any solution suggestion is appreciated.
Did it show an error code in the display?
If it showed H-98 or similar the magnetron has failed.
It is not a customer repairable item. Take it or have an Authorised Panasonic service centre look at it.
Jan 19, 2011 | Panasonic NN-T694SF Microwave Oven
H98
The high voltage generator or magnetron has failed.
It is not a user repairable item and must be directed to an authorized Panasonic Repairer for service as it is TOO DANGEROUS TO WORK ON without the specific training and tools.
Jan 12, 2011 | Panasonic NN-SD997S Microwave Oven
H97 fault code on a micro wave. What is the estimated cost to fix? Is it cheaper to buy a new one?
Either te magnetron has failed or the invertor has failed.
How long is a piece of string.
Ask a Panasonic Authorised Repair Centre for an estimate.
Jan 07, 2011 | Panasonic NN-S541 Microwave Oven
Panasonic dimension 4 microwave/convection oven Micvrowave part of oven not working, convection oven/grill fine. Is it a problem with the magnetron? Is there some form of internal fuse?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 31, 2010 | Panasonic NN-C980 Convection/Microwave...
My Panasonic NN- 553BF microwave oven is not heating but all the lights and everything else works
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 21, 2009 | Panasonic Microwave Ovens
My panasonic NN-T945SF starts, runs for a few seconds and then shuts off. And I smell rubber burning.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Sep 07, 2009 | Panasonic NN-P794SF Microwave Oven
Wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jan 15, 2009 | LG LMV1314 Microwave Oven
Oven shuts off on cook after about 2 seconds
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Your actual model number is located on a tag around the control panel frame, door or below the cooking cavity.
Jan 12, 2009 | Panasonic NN-T654SF Microwave Oven
Microwave Ovens Logo
80 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
