Question about Apple MacBook Mac Notebook
MacBook Pro intel, CD stuck not mounting or ejecting
Stuck CD reading it but not mounting or ejecting
    Habit-Forming:
  • 53 Answers
While restarting, push and hold your mouse button during the entire boot sequence. this will force the ejection of the cd.
Posted on Jun 04, 2009
Get a stuck cd out of a macbook
Try rebooting with mouse down. Should eject all ejectable media. If that doesn't work, take it to service (Apple or other) - they have tools to do the job. Don't force it.
Feb 06, 2015 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
How do you force eject a disc from a macbook pro?
Five ways to eject a stuck CD or DVD from the optical drive
Ejecting the stuck disc can usually be done in one of the following ways:
1. Restart the computer and after the chime press and hold down the left mouse button until the disc ejects.
2. Press the Eject button on your keyboard.
3. Click on the Eject button in the menubar.
4. Press COMMAND-E.
5. If none of the above work try this: Open the Terminal application in your Utilities folder. At the prompt enter or paste the following:
/usr/bin/drutil eject
If this fails then try this:
Boot the computer into Single-user Mode. At the prompt enter the same command as used above. To restart the computer enter "reboot" at the prompt without quotes.
Regards,
Alex
Aug 14, 2014 | Apple MacBook Pro Laptop Computer with...
Eject cd from external Disc Drive
https://discussions.apple.com/thread/5737052?tstart=0
Jan 17, 2014 | Apple MacBook Pro Laptop Computer with...
How to eject a cd
A few ways of doing this
1) restart mac and press down the trackpad button after you hear the startup noise
2) if that does not work try opening up disk utility which is located in applications and then in the utilities folder and click on the icon of your disk under the left hand column then go up to eject button and click eject
3) or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
4) Finally what to do is try pick up your macbook tilt the
macbook to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
However, I would say that DVDicon1.png drives in all macs are a bit suspect and if your macbook is still under warranty or under AppleCare take it back to the Apple Store and tell them that the DVD drive is faulty and they should replace it free off charge. Hope this helps.
Apr 30, 2013 | Apple MacBook Pro Laptop Computer with...
Cd stuck in mac laptop
2) if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
imac to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
However, I would say that DVD drives in all macs are a bit suspect and if
Feb 18, 2013 | Apple MACBOOK PRO 13 INCH NOTEBOOK 24 GHz...
Stuck disc in Macbook pro
CD and DVD drives have a manual release.On the door,look for a small hole.You an usually insert a paper clip in this hole to manually release the latch and open the door.
Jul 31, 2012 | Apple MacBook Pro Laptop Computer with...
A dvd has become stuck in my macbook and when i reboot, the screen remains blank and will not start up
If it is physically stuck, you will need to take it in for service.
If you just need to eject it, hold down the eject button or the trackpad button as you power on and continue to hold it down until the disc ejects.
Dec 29, 2010 | Apple MacBook Pro Laptop Computer with...
Hi- I've just inserted a CD into my MacBook Pro
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Oct 13, 2009 | Apple MacBook Pro Laptop Computer with...
Cd stuck inside
Turn the computer off. Turn it back on and repeatedly press the eject key. The CD will eject before the computer starts back up.
Jul 07, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Macbook cdrom stuck in copy mode
hold down power button until your machine shuts off. then power back on. you should be fine. if the cd is stuck in the drive, restart the machine and hold down the mouse button while restarting - the cd should eject itself.
Sep 02, 2008 | Apple MacBook PC Notebook
Apple MacBook Mac Notebook Logo
901 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
