BUSH TV is stuck in standby, tried turning off from mains but nothing, tried holding down the power button for 2 min with mains turned off, then mains back on while holding power button for a further 2 min, still nothing..
Blinking of power light indicates there is something fault with internal circuit. These are called blinking codes. If you wish to know more about blinking codes to Bush TVs, check this link. Pull up older posts there.
SOURCE: Hi i have a 40inch
Is there anything power signal lights?If there is no signal power lights,it is totaly dead set no power.First step is to check the power outlet,then the AC cord if there's a ac power.If the AC cord is good,check the fuse,located at the power supply.Replace same value of fuse if busted.Try this sugestion or procedure.Thankss...
