Question about Alpine PDX-4.100 Car Audio Amplifier
Amp doesnt work
Okay, my amp was working fine for about 3 weeks.  I was listening to music one day last week when the volume cut out completely.  The power light on the amp was slightly flickering.  Headunit and all connections check out.  Now the amp was cutting on occasionally, but when I went to try and fix it I found pushing in hard on the fuses would make it play.  After doing that though it wont cut back on at all now.  Any suggestions?
  • Colorada Oct 25, 2007
    it was new when I bought it but, it was on ebay.  Thanks for helping me though.  What should I try?
  • 631 Answers
If you've only had it for 3 weeks and it's under warranty, you need to send it to a warranty station.
If there is no warranty and you want to try to find/repair the problem yourself, let me know.
Posted on Oct 24, 2007
  • Perry Babin Oct 25, 2007
    There's no guarantee that you can repair it and you could make a mistake that could cause more damage.
    If the fuses are tight in the holders and pull out evenly (both contacts have equal pressure on the fuse blades), there are likely broken connections on the holders or on the power connectors. If you want to remove the cover, you would look for broken/cracked solder connections. If you see a ring around the solder joint, it's likely a broken connection. Since yours has been intermittant, it should be obvious.
    Do NOT power up the amp while it's out of the sink. When you do apply power, all power semiconductors MUST be clamped tightly to the heatsink.
    I'd suggest that you read the text in the yellow box on the following page:
    http://www.bcae1.com/repairbasicsforbcae...
    Let me know what you find.
Zx750.1 kicker amp cutting out
Also check your fuses. there may be a fuse for the in-tank fuse.
Jan 05, 2014 | Kicker (ZX750.1) Car Audio Amplifier
AC furnace huming
Blower motor & or capacitor bad
Jul 10, 2013 | Heating & Cooling
I bought the amp a few weeks ago and it worked perfectly for a couple of days and then for some reason the controlls just froze. the tap tempo light went out and the channel control light stayed the same...
Exercise your warranty IMMEDIATELY since you just bought it! If you bought this used, you LIKELY bought someone else's problem. The problem is likely in the digital effects area... probably a bad cable contact... but if under warranty DO NOT mess with it... return it for replacement or repair.
Sep 09, 2011 | Marshall Amplification Marshall MG30FX...
Cant hear any sounds. music or phone calls
1-Check & see if Mute is on.
2-CHeck & make sure ringer volume is on (settings from Main screen,pressing 4square looking button)
3-Turn phone completely OFF,kinda like resetting it,my phone does this occasionally & does fine if i restart it.
If this doesnt work---Clarify your Prob a lil more & go from there.
Sep 06, 2010 | Motorola Mobility CLIQ Cell Phone
Amp not working
Make sure you have the amp grounded. I put one in last week and would not work till I grounded the amp to the car....Run a seperate wire to the car/truck.
Dec 22, 2009 | Power Acoustik Car Audio & Video
6 mnths old Alto L8 Mixing desk developed hiss on channel 1 only.
The slider or the amps for channel 1 may have a problem.
Sliders do wear out.
Try shorting channel 1 input and see if that affects the noise. A hissing noise is probably a bad preamp chip. That is shop work at a repair facility.
Aug 16, 2009 | Music
Why does my KAC-8404 cut off at high volume bass?
amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Dec 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
No bass at higher volume
Your battery should be fine! Although the amp might not be strong enough for the sub. All you can do is check the RCA cables from your radio to your amp as these might vibrate loose when you get to 17 volume and also check the monster cable from your amp to your sub asit might have vibrated loose as well.
Oct 21, 2006 | Pioneer GM-5200T Car Audio Amplifier
Alpine PDX-4.100 Car Audio Amplifier Logo
155 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
