Question about Alpine CDA-7930
How to separate the face plate housing from the player
Am trying to remove the player from its mounting location. The installer has attached the unit to the dash. I am having trouble separating the face plate housing from the player, in order to remove from the dash. Any suggestions ?
  • 87 Answers
It sounds like you need a din size extension. Metra and Schosce both have them. It goes behind the can then mount the can to that and your dash. If it is and ISO mount (radio mounted to brackets in the dash) the its in the wrong screw holes.
Last would be to file the dash bezel to allow fitment.
Posted on Jun 02, 2009
I needed to replace climate control unit on1997 Grand Am GT. Concerned with how to remove the cluster face panel w/o breaking it.
Let me know if this helps out.
Heater & Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the screws securing the cluster trim plate to the instrument panel.
  3. Tilt the top of the cluster trim plate downward releasing the clips that mount the bottom of the trim plate to the dash. Remove the trim plate.
  4. Remove the screws attaching the accessory trim center plate to the dash.
  5. Tilt the top of accessory trim plate downward releasing the clips that mount the bottom of the plate to the instrument panel. Remove the plate.
  6. Remove the screws attaching the control assembly to the dash.
  7. Remove the control assembly from the dash.
  8. Disconnect the control assembly electrical connectors.
  9. Remove the control assembly.
To install:
  1. Install the control assembly.
  2. Connect the control assembly electrical connectors.
  3. Install the control assembly attaching screws.
  4. Push the mounting clips into place and roll the top of the accessory trim plate upward into position.
  5. Install the screws attaching the accessory trim plate to the dash.
  6. Push the mounting clips into place and roll the top of the cluster trim plate upward into position.
  7. Install the screws attaching the cluster trim plate to the instrument panel.
  8. Connect the negative battery cable.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 40; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Jan 23, 2011 | Pontiac Grand Am Cars & Trucks
I need to put a crankshaft sensor but I don't Know its location I already changed the cam sensor. Ronnie
The crank sensor is located on the engine near the flywheel axis of the crankshaft.
Crankshaft Position Sensor Removal & Installation To Remove:
Location of the crankshaft position sensor on the 3.3L and 3.8L engines 91154g21.gif
NOTE: On the 2.4L engine, the crankshaft position sensor is mounted to the engine block behind the alternator, just above the oil filter. On the 3.0L, 3.3L and 3.8L engines, the crankshaft position sensor is mounted on the transaxle housing, above the vehicle speed sensor.
  2. Raise and safely support the vehicle.
  3. Disconnect the crankshaft position sensor electrical connector.
  4. Unfasten the sensor mounting screw, then remove the sensor from the vehicle by pulling it straight out.
To Install:
NOTE: If the sensor removed is going to be re-installed, clean off the old spacer on the sensor face. A new spacer must be attached to the sensor face before installation. If the sensor is being replaced, be sure that a paper spacer is attached to the sensor face.
  1. Install sensor and push the sensor in until contact is made. While holding the sensor in this position, install and tighten the mounting bolt to 105 in. lbs. (12 Nm).
  2. Connect the crankshaft position sensor electrical connector.
  3. Lower the vehicle.
  4. Connect the negative battery cable.
Jul 31, 2010 | 1996 Plymouth Grand Voyager
How to replace the water pump on a 1992 geo tracker 1.6 liter engine
Water Pump - REMOVAL & INSTALLATION
During these procedures, identify all components removed from the engine so that they may be reinstalled in their original positions. If discarding the old components so that new components can be installed, identifying the old items is not necessary.
1.3L and 1.6L Engines
  1. Remove the timing belt cover, timing belt, tensioner, plate and spring.
  2. Remove the water pump mounting bolts.
  3. Remove the one (1.6L MFI engines) or two (1.3L and 1.6L TFI engines) small rubber seals from between the water pump and the oil pump, and the water pump and the cylinder head.
  4. If necessary for clearance, remove the oil level dipstick tube retaining bolt from the engine block and the alternator adjusting brace.
Fig. 1: Exploded view of the water pump mounting
WARNING Do NOT use a prybar between the water pump housing and the engine block to separate the two components; this can cause scratches and/or gouges, which can prevent proper sealing.
  1. Pull the water pump off of the engine block. If the water pump is difficult to remove from the engine block, use a soft-faced mallet to tap the water pump housing until it loosens.
Do not disassemble the water pump; if the water pump is damaged or defective, the entire unit is replaced.
  1. Thoroughly clean the water pump gasket mating surfaces of old gasket material and corrosion.
To install:
  1. Along with a new gasket, install the water pump on the engine block. Tighten the water pump mounting bolts to 88-115 inch lbs. (10-13 Nm).
  2. On 1.3L and TFI 1.6L engines, install two new rubber seals: one between the water pump and oil pump, and the other between the water pump and the cylinder head. The MFI 1.6L engines only use one rubber seal, located between the water and oil pumps.
  1. If removed, install the alternator adjusting brace and the oil level dipstick retaining bolt.
  2. Install the timing belt, tensioner, plate, spring and cover.
Hope helps (remember comment and rated this).
Jul 19, 2010 | 1991 Geo Storm
How to replace front turn signal housing
Front Turn Signal & Parking Lights
  1. On some models you will need to remove the headlight bezel mounting screws and the bezel.
  2. Remove the mounting screws for the lamp assembly.
Remove the mounting screws securing the lamp assembly
  1. After the screws are removed, pull the assembly from the vehicle.
  1. Disconnect the twist lock socket from the lens housing.
To remove the bulb, turn the twist lock socket (at the rear of the housing) counterclockwise 1/4 turn, then remove the socket with the bulb; replace the bulb if defective.
Newer Oldsmobile models have the turn signal separate from the headlamp assembly ...
... unlike the newer Buicks, where the unit is attached to the headlamp
To install:
  1. Install the electrical harness to the back of the unit.
  2. Position the signal assembly, then attach to the vehicle with the mounting screws. Tighten the screws to 54 inch lbs. (6 Nm).
  3. Insert the socket to the back of the unit, then attach the headlamp bezel if removed.
Feb 13, 2010 | 1992 Oldsmobile Cutlass Ciera
Change front turn signal light?
To install:
Oct 31, 2009 | 1990 Pontiac 6000
Replace heater blower motor 96 neon
With Air Conditioning
  2. Remove the right side scuff plate.
  3. Pull back the carpet from the passenger's side floor.
WARNING Be careful not to cut into the blower motor wiring!
  1. Use a suitable utility knife to cut the wheel housing silencer in line with the blower motor wiring.
  2. Detach the blower motor electrical connector.
  3. For right-hand drive vehicles, remove the motor cover.
  4. Unfasten the three blower motor retaining screws, then lower the blower motor assembly from the unit housing.
The blower motor assembly is located under the passenger's side dash panel
Blower motor mounting and location of the retaining screws and wiring-vehicles with A/C
To install:
  1. Raise the blower motor into position in the unit housing and secure with the three retaining screws.
  2. If removed, install the motor cover.
  3. Attach the blower motor electrical connector.
  4. Use tape to secure the silencer into position.
  5. Reposition the passenger's side floor carpeting.
  6. Install the right side scuff plate.
  7. Connect the negative battery cable.
Oct 25, 2009 | Chrysler Neon Cars & Trucks
I have a Dual XDM7510 and i can't figer out how to get the face plate off of it
Hello sneary_08,
The front panel was semi-permanently attached during
assembly. In order to be removable, the installer is required to follow specific procedures contained in separate instructions. If the installer did not perform the procedures, the front panel will not be removable.
If the procedure was followed during initial installation, then you can remove the front panel as follows:
With the unit off, press OPEN to allow the front panel to slide
down. Gently squeeze the release tab located on the bottom
center underside and pull front panel down and away from
unit to remove. To install, insert left side first, then push
right side to secure.
Hope this helps.
Jun 01, 2009 | Virtual Reality Sound VR3 CD Player w/ USB...
A dvd is stuck in my Chrysler town and country multi disk dvd/ cd player. How do I remove it?
Look around the face plate for a very small hole...use a straightened paperclip or equivalent and press in a few inches...its a manuel door release and you should gain access to at least the loading tray.
Apr 24, 2009 | 2005 Chrysler Town & Country
Stereo issues
I'm assuming that you installed the head-unit new and that the faceplate did (at one time) previously slide down the way it was intended to work - is this assumption correct?
Is the molding around the head faceplate (mounting ring) damaged?
Are you sure you're not using the semi-permanent mounting configuration??
(see page 6 of the manual)
This particular unit has the option for a semi-permanent mounting of the face plate. If the two screws are inserted into the sides, it will lock the face plate in to the head unit (have you done that?) - if so, removing the screws will allow the face plate to be removed.
May 29, 2008 | Dual Electronics BDS692 Coaxial Car...
DUAL XD7500 CD PLAYER PROBLEM
This is what the manual says:
center underside and pull faceplate down and away from unit
to remove. To install, insert left side faceplate first, then push
Tried it and couldn't get it out.
Sep 05, 2007 | Pioneer DEH-P44 CD Player
Car Audio & Video Logo
130 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
