Question about Vehicle Parts & Accessories
Hazards keep flashing
When locking up my kalos 54 plate with the key remote , when set if any thing rocks the car slightly the hazards start flashing
  • 87 Answers
Sounds like the shock sensor/vibration sensor is way to sensetive. Adjust it to a lower settin and that should resolve the problem.
Posted on Jun 04, 2009
What's your question?key program code for 06 xterra
1. Close and lock all doors with the driver's side power lock / unlock switch located
on drivers door panel.
2. Insert key into ignition and remove it from the ignition key cylinder at least 6 times
within 10 seconds. Your hazard lamps will flash if you have performed this step
successfully. NOTE: Withdraw key completely from ignition cylinder each time. If
this procedure is performed to fast, system will not enter programming mode.
3. Insert key into ignition and turn to the ACC position.
4. Within 5 seconds, push ANY button oon the keyless remote. Your hazard lamps
will flash. NOTE: Do not press the button on the remote more than one time or the
programming will not be successful.
5. If there are any remaining remotes (including old ones), Unlock then Lock all doors
using switch on drivers door panel and within 5 seconds press ANY button on the next
remote. Your hazard lamps will flash. Repeat this step for each remote (including any
existing remotes).
6. Turn key to the off position, remove key from the ignition. Unlock door using switch on
door panel and open drivers door.
7. Test remote(s).
Jun 27, 2016 | Cars & Trucks
Why does my remote start just make the car horn beep and security lights flash but doesnt start?
it sounds like security start relay malfunction ,check and or change out relay.
Sep 07, 2014 | 2007 Chevrolet Malibu
How do you program new spare key for 2007 rodeo RA?
if its the ignition key it must be done by a dealer and have a lage black plastic head which has got a transponder in it. If you got a blank key cut at the locksmith it will turn the locks but wont start the car. Usually you get the dealer to do both supply ignition key and then get it cut, then they can program it.
but if your asking how to program the keyless entry remote follow this procedure.
take note step 5 is different for different year models.
Make sure that all the doors are closed and unlocked and wait for dome light to go out before starting.
Insert the ignition key into the ignition switch
Open drivers door
3 on/lock
Close/open drivers door
Wait 8 secs
On/lock/on (MY06-07) OR 2 on/lock OR on/lock (MY08)
Close drivers door
Hazards flash
Press remote & keep pressing one button & then the other slowly(2 secs) until locks start working(they wont operate if key is in ignition).
Hazards flash
Feb 23, 2011 | Isuzu Rodeo Cars & Trucks
Set keyless remote for Nissan xterra
Key Fob Programming instructions...
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder
each time. If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming
procedure will not be successful.
5. If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver’s side
power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should
flash. Repeat this step for each transmitter (including any existing transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Jan 20, 2009 | RCA RCR311B Remote Control
Need to program remote keyless entry for 2003 nissan pulsar?
If it is a 2003 model year vehicle follow this procedure. If it doesn't work, you may have the wrong fob which happens all the time.
Sit in vehicle and close all doors.
COMPLETELY insert and remove ignition key more than six times within 10 seconds.
Hazard lights should flash twice.
Turn ignition to ACC position
Press and hold any button on the new key fob hazard lights will flash twice
For a second key fob using the master lock switch, lock and unlock the doors then hold down any button on the second remote until the hazard lamps flash twice.
Then you are done open the door to exit the programming mode.
If the lamps didn't flash when holding down the key fob make sure you have the right key fob, they are different for each car.
Nov 25, 2008 | 1990 Nissan Pulsar
Ihave a 1996 Nissan Maxima. I am unable to use the remote keyless entry. I changed the battery but still no good.
You need to program it. Here is how you doit.
Step by step:
1- get inside and lock all door with the "power dool lock switch"
2- insert the key into the ignition 6 times "IN and OUT" nice and steady until your hazards flash on dashboard. You can just keep inserting the key until you see the hazards flash, but 6 times should do it / get you into the program mode.
3-once the hazards flash, turn the key to ACC position (dash light up, but car is not running)
4-press any button on the remote (hazards should flash)
5-turn key OFF
6-remove key
7-unlock door with "power door lock switch"
8-open door DONE.
Good luck
Oct 14, 2008 | 2003 Nissan Maxima
Programing a remote on a 99 quest
first make sure,that the batter is ok. You will need to have both remotes while doing this.
1: get in and lock the doors with the power door lock
2: insert the key into the ignitoin repeatedly IN and OUT 6 times in a row or just keep doing so, until the hazard flashers flash on the dash board (observe the dash board while inserting key)
3: after the hazadrs flash TURN key into the ACC position/not start.(dash will light up) DO NOT START
4: with the key in ACC position, hit lock button on the remote. That will program that remote.
5: to program the other remote simply unlock the door with the door lock switch and relock it with the swithc and hit the other remote button.
6: done
Sep 16, 2008 | 1999 Nissan Quest
Nissan Murano 2005 SL keyless entry remote programing, got a used remote, how can I program it?
Close all vehicle doors, LOCK doors using drivers side switch.
Insert key all the way into the ignition, (do not turn) remove key.
Repeat this step 5 times. (6 total)
Hazards should flash to indicate program mode.
Press any button on transmitter to be programmed, hazards should flash to indicate successfull program.
*For additional remotes, cycle drivers door lock UNLOCK, LOCK, press any button on remote, hazards should flash. Repeat step as necessary.
Ignition ON, (engine off) ignition OFF, UNLOCK using drivers side switch, test remotes.
Source
Aug 06, 2008 | 2005 Nissan Murano
Keyless entry keylob want lock or unlock doors or trunk.change battery and checked all fuses.
You need to program the remote. Get in to the car and LOCK all doors with the switch on drivers side door. Take the key and insert it into the ignition cylinder in and out 6-10 times, until the flashers/hazards flash on your dash board. Or just keep putting the key in and out (nice and easy now, not fast) until you see the lights on dash flash. After the lights flash, turn the key into ACC mode to make the whole dash light up.(do not start car) .With the key in ACC position, hit any button on remote, that will make the hazards flash again. Turn key off and unlock door with switch again. Open door.DONE.
Good luck.
Jul 15, 2008 | 2001 Nissan Altima
Vehicle Parts & Accessories Logo
100 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
