Question about Motorola Mobility E815
Main screen blank
The front outside screen looks normal, but when you flip it open to the main screen it's just snow white.  Actually if you look at it from an angle it appears that the top 1/4 is dark blue and the rest is white. This seems to be a phenom as a couple people are reporting this issue within the last 24-48 hrs.  The cell still dials out and makes & receives calls (although you can't see the display now of the numbers dialed) but obviously texting is out of the question.  I've "updated" the phone (*22899 via Verizon to update the software) & have taken the battery off & done all of the known simple fixes already.
  • 2 more comments
  • schutnstar Nov 04, 2007
    My main screen has gone blank also and looks perfect from the external screen. Occasionally my wallpaper will come back up and the phone will appear to be normal but will not function. Sometimes the screen will just go completely haywire and begin to change colors from green to purple and when I turn the camera on from the side button the screen looks like a TV on a cableless channel. Phone was perfectly find one minute and messed up the next!
    This must be a huge conspiracy! Any suggestions?
  • misspiggy696 Oct 04, 2008
    Same here. My boyfriend just got my old phone switched to this one today and it's already giving me problems.
  • tedsummer Nov 02, 2008
    i have the same problem. has anyone had this fixed?
  • Anonymous Nov 05, 2008
    same problem...my screen went blank/white today...could not do anything. I think it is a bug with the phone and we need to contact Motorola...could have to do with DST.
Same problem here...must be a bug with the phone or has to do with DST..Appears all E815's will not work.
Posted on Nov 05, 2008
Casio g'zone phone with broken screen main screen.
This is most likely a broken data ribbon. It is a few very thin wires that connects the mother board of the phone to the screen and can easily break with flip phones. It can be replaced and new data ribbon is cheap.
Oct 05, 2013 | Casio G Zone C751 Ravine Verizon Cell...
My problem is my inside screen went blank white. About a week ago the inside screen started to do weird stuff like one day it had multi colored snow. The next it went blank. The next it looked like liquid...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Oct 05, 2010 | Motorola Mobility E815
Take care.
I have a flip phone samsung cricket phone and i can still get calls the front screen works i can dial numbers numbers light up it makes sound but when i open it... The main screen is always white???
Good luck.
Jul 02, 2010 | Cell Phones
My girlfriend's nokia cell phone all of a sudden yesterday made a odd chiming noise and when she opened it up the screen she had was completly backwords for a few moments and then it went blank...can see...
If its a flip or slide handset, then the flex ribbon is damaged, this will need to be changed...
Sliding and flip phones have a thin ribbon, which connects the phones screen and any buttons that are at the top to the phones main PCB... A damaged one of these can cause anything from no display at all, white screen, fuzzy colours, rotated screen, dodgy bits, non functioning buttons and lots of other things.
Depending on your model you may be able to get a ribbon from somewhere like ebay and fit it yourself, some are more awkward than others, there should be a guide available somewhere, however it does depend on which phone it actually is :)
May 08, 2009 | Nokia N70 Cellular Phone
Screen gets distorted and turns white
The part that is bad is the Ribbon flex cable that geos from the main board to the LCD board. Over time the cable becomes chaffed and will lose continuity between the traces. It can be fixed with
Tessco Part #: GH97-07715A
It does need to be soldered on the LCD side.
Apr 25, 2009 | Samsung SPH-m520 Cell Phone
Open/closing diaplay problem
replace your phone
Oct 07, 2008 | Cell Phones
Blank white screen
when switched on the phone,my phone screen only show nokia and i want to turn off cant. how to solve this problem?
Feb 08, 2008 | Nokia N76 Cellular Phone
My phone displays a white main screen
My Solution: Heat it up by just sitting on it or holding it in your hands// Take the battery out and back in/ Try keeping the battery out of it for a full day
My Story :) My mom dropped the phone in the dishes because she was drunk haha, I quickly took out the battery, but when the next day came by I looked at the phone and saw the same problem everyone here has. I kept replacing the battery on the hope it would just magically fix itself. Now 2 days from when it dropped in water, I kept flipping it, replaced the battery again (just taking it out and back in) after I sat on it a while, possibly the heat somehow helped it to work again.. I'm amazed it works haha, it was in the water fully submerged for half a min when I had to snatch it out of the dishes But, it is most likely that I took the battery out, the battery is the thing that ruins electronics, just remember to take it out if you drop it in water. Good luck. If worst comes to worst and your going to buy a new phone, maybe try using a blow dryer on it for a little bit **or just do this in the first place**
Jun 28, 2007 | LG VX8300 Cellular Phone
My motorolae815 phone screen is having problems :(
I HAD THE EXACT SAME PROBLEM AND AFTER SEARCHING INE INTERNET HIGH AND LOW, I FOUND A MOTOROLA WEBSITE THAT ASKED ME FOR MY PHONE SERIAL NUMBER (TO VERIFY WARRANTY INFO). I REMOVED THE BATTERY TO LOOK FOR THE SN AND AFTER PLACING IT BACK IN THE PHONE AND, AFTER POWERING IT BACK UP - WA LA - THE SCREEN WAS BACK TO NORMAL! GOOD LUCK!
Dec 09, 2006 | Motorola Mobility E815
Motorola Mobility E815 Logo
193 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
