Question about Emerson EWF2704 TV
The picture is to bright
I have the brightness turned all the way down and the picture is to bright. When I turn brightness up it shuts down and will not stay on unless I hit Game button and turn brightness down. my model is a emerson 27inch color TV model# EWF2704, you have none of them listed. But am having the same problem, screen is to brite and when I try to adjust it shuts off. pix is to brigth
  • Robert Smith Aug 10, 2009
    iam thank you with a sev m some time it a pane in the ass it was the flyback thank you.
  • Robert Smith Nov 20, 2013
    it t was the rest behing the fly back
    Problem Solver:
  • 13 Answers
Problem in high voltage area, consult an expert
Posted on Jun 02, 2009
Picture gets darker when light in room is turned off!
The "auto" illI nation is turned on so it will dim when the lights go down so the unit is not too bright. You can adjust the brightness when the lights are on which shold also effect the brightness when the lights are off or turn off the auto-brightness control.
Nov 26, 2016 | Televison & Video
Tcl tv screen
hi go into the menu on your tv scroll to picture setting turn the brightness down also look for bl which means back light set it to about 10 hope it helps
regards
shaun
Jan 25, 2014 | Televison & Video
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Turn on pic turns red with thin bright red horizontal lines
Sorry to say, but that's usually the sign of a bad picture tube. One of the elements inside the tube shorts and you see the picture you describe, and the set shuts down due to high voltages getting to places it shouldn't. There's no solution except picture tube replacement, and that is uneconomical. You're better off replacing the TV when the tube goes bad.
Mar 31, 2009 | Toshiba Televison & Video
Turns itself off
screen control. pict to bright. normal to shut down. when this happens. ****** screen control.
Nov 19, 2008 | Zenith B25A10Z 25" TV
Aadjusting screen colors
They should be adjusted to set voltages. however it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels. Hope this helps.
Feb 01, 2008 | Hitachi 57F500 57" Rear Projection...
Mitsubishi VS-6041- picture brightness not very bright
Hi Dawn,
The TV does have a screen control on each of the picture tubes ( there are 3 ) although I do suggest you have a qualified technician make the necessary adjustments as an improper adjustment can cause damage to the set. Should you deside to make these adjustments yourself, you'll need to remove the back ( or front in some sets) ( PRE-CAUTION, UNPLUG THE SET FROM THE WALL BEFORE PREFORMING ANY ADJUSTMENTS INSIDE THE SET ) The screen adjustments are located either on the bottom of each tube or in a group component located where the main High Voltage Wire ( large red wire from the black transformer on the deflection board ) is connected to. Look for a turn pot ( screw type adjustment ) that is marked SCREEN. When you locate it ( whether it be on each tube or in the group component ) turn it up only slightly and not to much, as excessive gain ( turning it up to much ) may cause the TV to shut down. When you have the proper brightness ( when it looks good to you ) close the set up and enjoy the renewed picture. Good luck and I do hope this has helped in some way
Ed
NC Electronics
Mills, Wyoming
Nov 18, 2007 | Mitsubishi VS-6041 60" Rear Projection...
I have sound but no opicture
When you replaced the flyback the new flyback is shipped with the screen and focus controls set at minimum. These are the 2 controls on the flyback itself. Turn the set on and let it warm up a minute, then slowly turn up the screen (bottom) control with a small flat-head screwdriver. When the picture is around normal brightness, adjust the focus (top) control until the picture is nice and sharp. Then, turn the brightness and contrast all the way down and set the screen control until you can just see the picture, just above the point where the picture vanishes. Reset the brightness and contrast settings and your picture will be back to perfect.
Jul 02, 2007 | RCA F36650 36" TV
if you are a tech open the tv and turn down the brightness from off the flyback screen adjustment if that does not work then the flyback will have to be replaced.it is defected.good luck
Apr 19, 2007 | Emerson EWF2703 27" TV
Emerson EWF2704 TV Logo
169 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
