Disconnect any speaker from the amp then re-power. If it still goes into protection, your amp needs serviced. Shorted output transistors most likely. And check your Sub for shorts as well. If the voicecoil on the sub is burnt, it will short any amp. If you can use a meter, check the resistance on the sub. Hope this helps
Protection light comes on went the amp is turn on and it stays on for four seconds and then the amp...
(More)
Protection light comes on went the amp is turn on and it stays on for four seconds and then the amp turn on
kx1200.1 2 15" kicker cvr ran at 1 ohm sounds great hits hard but when i get up around maxing...
(More)
kx1200.1 2 15" kicker cvr ran at 1 ohm sounds great hits hard but when i get up around maxing it out it bumps off and on but doesnt clip or go into protect, green light stays on and music countinually goes in and out at the loud level.
Yes tech guru my kicker one day working next not having any out put to the subs. I took it to the...
(More)
Yes tech guru my kicker one day working next not having any out put to the subs. I took it to the stereo shop and they checked the power supply and everything running 12-14 rms. So what's the problem? should i pulled the amp and sending it to the factory for repair? help me if you think there's a fuse or something i can pull and plug and play again?
