2009 Jaguar XF Supercharged Logo
Jonpaul Simpson Posted on Jan 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Squeaking rotary noise from engine
Hi, When I start the car there is a squeaking from the engine which sounds like it is rotating. This often stops after driving for 15 mins. Had the belts checked and they are fine. Any help greatly appreciated. Thanks JP
George Hels
Level 3:
  • Master 528 Answers
  • Posted on Jan 25, 2014
George Hels
Master
Level 3:
Answers
528
Questions
Helped
159738
Points
1647
It is possible you have a glazed belt - it is fine, it just slips until it warms up. If you have "V" belts, there is a belt dressing you can spray on that will cure the problem. If you have serpentine belts ( a wide belt that has several ribs on the inside ) you can us a small dab of Dielectric grease on the belt. smear a small dab across the ribs of the belt ans start the engine - the squeal should go away quickly.
Hope this helps!
2 Related Answers
Anonymous
  • 416 Answers
  • Posted on Dec 02, 2008
SOURCE: check engine light came on while engine was off, but ignition on
It might be the battery, check the voltage somewhere for instance in AutoZone store (they do it for free)
Anonymous
  • 410 Answers
  • Posted on Aug 10, 2009
SOURCE: IDLING PROBLEM
Sounds like it is your Idle Air Control valve. The IAC is located on the throttle body and is normally held on with a couple of screws. Normally I tell people to just replace them because they are relatively cheap but it isn't for your car so I would suggest that you take the part of and soak it in some throttle body cleaner. Let the part air dry and if you have it blow some compressed air in it to dry it very good before you put it back on the car. There is a 99% chance this will get your car running normally again. Please let me know if you have any further questions. Thanks for using FixYa!
My 2001 xterra started making a weird sound between 20 and 35 mph. It sounds like there is a leak in some pressure system.
Common Car Noises and Their Likely Causes Noise More Details Likely Cause Fixing It Clicking noise while turning Starts faint, gradually becomes more noticeable until very loud Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age Replace either the whole axle assembly (recommended) or the outer CV joint Water pump noises Difficult to diagnose because of water pump's location Noise usually caused by damage to the bearings in failed water pump Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs Squeak or squeal from an engine belt Loud, high-pitched squeak or squeal Belts either need adjustment or replacing If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced Exhaust heat shield noises Rattle that you hear when car is idling Damaged heat shield Replace heat shield
Loud squeaking coming from left front of car
Hi Tim:
Possibles:
- Engine running but vehicle stopped. - Fan belt or bad bearing in rotating accessory like alternator or water pump.
- Vehicle moving - Worn brake pad. Little metal tab drags on disc and makes squeak to tell you it's time to replace.
- Vehicle not moving, engine not running - Tire parked on neighbor's cat's tail.
Mazda protege makes a squeaking noise when I start driving?
If your Mazda Tribute's engine has a rumbling noise when you start it, this is most likely from the drive belt. You will need to replace it.
2helpful
I am experiencing a squeaking noise from infront near the fan belt area. when i accelerate,it gets louder. I discovered that the power steering pump is leaking ,so i topped up the reservoir and it stopped...
i have a similar problem. a squeaking noise, sounds when i start the engine, and when i stop the engine. at times it comes when the engine is running and idle, and it lasts some time like a high pitched whistle. Ive had several mechanics look at it, and it seem to be one of the smaller pulleys that the belts run around. in the 2002 model (petrol) of the crv the belts are not the cam belts, becuase this model has a cam chain (much more robust!). so they all said its nothing to worry about. you can try having your pulley replaced.
Squeaking on 1999 toyota corolla
Throughout my experience with Toyota's I have found that several times the hubcaps have made some weird noises. Try removing your hubcaps and driving your vehicle. If the noise still persists please let me know and I can ask u some questions and try to help you with your problem.
Car squeaks at idle when warmed up
it could very well be just your serpentine belt is old, they usually squeak when worn. To solve that you can buy a spray at any local autoparts store to stop the noise for good, its called belt dressing. a slurping noise could be a range of things, the most common is your
a/c isn't fully charged with fluid, the noise your hear is the compressor trying to pull more fluid in **** only getting air, hence the slurping
2helpful
Steady squeaking noise after taking foot off accelerator
sounds like you have a pad rubbing on a disk/rotor, if you jolt the brakes does the noise go away? if so it's probably a pad loose
Squeak in front of engine 2002 taurus
I assume that the noise changes with engine RPMs, not vehicle speed since you mention washing down the engine - something pretty hard to do if the car is going down the road-
Is it possible that what you describe as a squeak is instead a whistle? The symptoms you mention related to water could mean that an intake manifold gasket (or another part of the intake system) has a bad gasket and is causing a whistling noise from air being pulled in where it shouldn't happen. If the failed gasket is allowing water into the intake system, that would explain why the engine sounds like it wants to die.
You might take a 2-foot length of vacuum hose or similar, hold one end to your ear and move the other end around the engine to see if you can more accurately isolate the source of the noise, be it squeak or whistle.    Obviously, don't hold the hose too tight in case you get tangled up with a belt or rotating part.
Good luck-
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
