Question about HP LaserJet 2200D Printer
HP 2200d - flashing amber light
The printer was working fine.  I recently changed to have it print two-sided pages by default.  I was printing a job and realized I wanted it to be only one-sided so I pressed the stop button.  The printing stopped and I withdrew the page from the back that had been printing.  I hit reset but the amber light still flashed.  I opened up the top, took out the cartridge, pulled out the drawer, opened the back to make sure no paper was still in there, unplugged everything and restarted it, but still get the flashing light.  Any suggestions.  Thank you.
  • mail189 Jun 02, 2009
    Problem has been solved.
    Scholar:
  • 113 Answers
I have a hp business jet 2250. Showing a code E-0041.
No manual for this machine.
Posted on Jul 27, 2009
How do you get the Lexmark pro 715 Printer to print on Both sides the manual is not very clear
1 With a document open, click File > Print.
2 Click Properties, Preferences, Options, or Setup.
3 Go to the:Layout tab > Print on Both Sides (Duplex) area > Print on both sides
- Click Long edge for print jobs with pages that are bound along the long edge of the page.
- Click Short edge for print jobs with pages that are bound along the short edge of the page.
4 Click the Paper/Finishing tab, and then select a supported paper type.
5 Click OK to close any printer software dialogs.
6 Click OK or Print.
Oct 22, 2012 | Lexmark Pro 715 All-in-One Printer
Amber light is flashing on network card
Switch off the printer, re connect the net work cable, switch on the machine & wait till ready mode comes.. Go to administration on control panel, select configure device,select configuration page, print,, total three print out will come, in that see the IP address.. If any IP address showing, ping that IP from system, if its pings, reload the drivers once again.. check for the print. If no IP adress showing in configuration page, try with another net work cable & try above said exercise.. Even no luck, remove formatter from the slot & re-fix once again & try... Even no luck.. it might be network port faulty. If its warranty contact HP support for free replacement.. If no warranty purchase HP620n or higher version of zetdirect card(net work card) install it... But take service engineers suggestion before replacing the network card..
Aug 01, 2012 | HP LaserJet M4345 MultiFunction Printer
Simple print question -
There should be setting in you printer settings or options, if you posted the actual printer name and model people may be able to help you better! If you only want to do a one off print job, print all the odd pages only. turn them over and print the even pages.
May 26, 2012 | HP Office Equipment & Supplies
How to stop Lexmark C540dw printing instructions for two-sided printing
I had same issue. I checked two sided printing, but wanted it to take the paper back in to the printer automatically. I did not have the duplex option selected in properties and it was showing how to do it by feeding the pages manually. Go to printer properties and printer preferences and I think the tab labeled page layout, you may have to select the advanced button to find the 2-sided options for flipping short end or long end. (you want flip on long end if you want the top of page 2 to be on the opposite side of page one. Other wise, flip on short end will put the top of page 2 opposite from the bottom of page 1). however, AUTOMATIC 2-sided printing will not work unless your model has the duplex printing feature. In that case you just need to go to properties and un-check two sided printing and check one sided printing. That way it will not keep wasting paper and showing you how to do it manually. So you don't have to do it for each print job make sure you change it in printer preferences so it does not keep trying to do 2 sided printing. If there is a job you want to print 2 sided then just select it in properties for that particular print job.
Apr 29, 2012 | Lexmark C540DW Color Laser Printer
Every time i print something I get TWO pages.. One what i Printed The Other ONe Plan Paper..So Every time i print i have to Remove the blank pages...lots of work as i run an office..HELP
It seems you have a problem with your printer's page and document settings.
To correct this problem run the Preferences application and change the default settings.
Select the Printer button.
In the next window, select the 'Change Defaults..' button.
Change both the Document size and the Paper size to a height of 10.875 and click OK.
Try a new document to see if the paper size is correct.
You may need to go back and change the height a few times until it is correct (the height changes in .125 increments).
Usually either 10.875 (for 1/4 inch forced top margin printers) or 10.75 ( for 1/2 inch forced top margin printers) will work.
Good Luck
Sep 23, 2011 | Canon MX700 Office All-In-One InkJet...
I am trying to set the printer to automatic duplexing...?
Hi
If you want to set Print on Both Sides (duplex) as the default setting for all print jobs (even single page jobs) use the following steps.
  1. Click Start , Printers or Printers and Faxes from the Microsoft Windows desktop.
  2. Right-click the HP Color LaserJet 2605dn_2605dtn and select Printing Preferences (Properties in Microsoft Windows 2000).
  3. Click the Finishing tab.
  4. Select Print on Both Sides under the Document Options section.
  5. Click OK to save the setting and close the Printing Preferences window.
  6. Close the Printers or Printers and Faxes folder.
Note:In this scenario, all print jobs, even single print jobs, will be treated as Print on Both Sizes (automatic duplexing) for media that is supported by the duplexing unit. For media that is not supported by the duplexing unit, the job will be treated as Print on Both Sides (Manually) (manual duplex).
Jun 13, 2011 | HP LaserJet P4014n Printer
I NEED TO PRINT DOUBLE-SIDED ON AN hp3150 LASERJET. hOW DO i DO THAT?
Follow these steps to change print settings, and then print in Mac OS X 10.6. Step one: Select your product
  1. In the program from which you want to print, click File , and then click Print . Figure 11: Click File, and then click Printc02458420.jpg
  2. Select your product from the Printer: drop-down list.
Step two: Change print settings
  1. Type the number of copies to print in the Copies text box.
  2. If you want to print multiple copies, select the Collated check box to print the pages of each copy in order.
  3. Select the pages of the print job that you want to print. To print all pages, select All. To print a specific range of pages only, type the page number that begins the page range in the From text box. Then, type the page number that ends the page range in the To text box.
  4. Select the size and type of paper loaded in the product from the Paper Size drop-down list.
  5. Select the orientation for your print job. To print in portrait orientation, click the icon on the left. To print in landscape orientation, click the icon on the right.
Step three: Change the paper type and quality settings
  1. After the Orientation section, click the drop-down, and then select Paper Type/Quality . NOTE: This drop-down usually defaults to the program specific drop-down. In this example, the drop-down is the TextEdit drop-down. Figure 12: Select Paper Type/Qualityc02458421.jpg
  2. Adjust the Paper Type setting to match the paper loaded in the product.
  3. Adjust the Quality setting to change the print quality of the printed page.
  4. Select Print Borderless to print photos without a white border.
  5. To change the color profile or to turn on Photo Fix, click the arrow next to Color Options to display the Color Options menu. Figure 13: Color Options menuc02458422.jpg 1 - Paper Type/Quality menu options 2 - Color Options menu (only available if you click Color Options)
Step five: Print the print job After all the settings match the needs of the print job, click Print on the Print window to print the document or print job.
Dec 26, 2010 | HP Photosmart C3150 Printer
HP 2200D Amber light keeps flashing! ..and nothing else
Following are the reasons and its solution for amber light keeps flashing:
1. Toner have been empty.
Sol : Refill you toner.
2. Printer's paper tray do not close properly or paper in not in the tray.
Sol : Close the paper tray properly and keep some papers in the tray.
3. Any door of printer is open or not properly close.
Sol. : Check all the doors that is close properly or not.
If problem is still remaining then contact a professional to repair this printer.
Regards
Ashly
Feb 25, 2010 | HP LaserJet 2200D Printer
Printer feeds blank pages.
often in the Printer properties, there is a tickbox, to feed a blank sheet between print jobs. this is to assist in keeping print jobs seperated on busy printers.
Here is the way to change the setting on a single print job:
  1. Click the Start button
  2. Point to Settings
  3. Point to Printers (Windows 2000) or Printers and Faxes (Windows XP).
  4. Right-click the HP LaserJet driver you plan to use (2420)
  5. Click Properties .
  6. On the Advanced tab, uncheck Separator Page.
  7. Click OK to return to the Advanced tab.
  8. Click OK to save the settings.
Making the change a permanent thing For All print Jobs on this printer:
  1. Click the Start button.
  2. Point to Settings .
  4. Right-click the HP Printer you want to correct the settings to.
  6. On the Advanced tab, click Printing Defaults .
  7. Change any of the settings on the tabs. These settings become the defaults for the printer.
  8. Click OK to return to the Advanced tab.
  9. Click OK to save the settings and to close the printer driver.
Sep 23, 2009 | HP DeskJet F380 All-In-One Printer
HP Laserjet 5000dn
if you using office go to page setup and select the tray(s) that you want to use for the first page and other pages ( both must be the same ) unless you only want the first page as letter head and the rest on plain paper or something along those lines ?
Also if you go into the properties of the printer and go to advanced and then click on the printing defaults button and see if the options in there are the same or different to whats in printing preferences.
If they are set to tray 1 then it will default to tray 1
Apr 13, 2009 | HP LaserJet 5000dn Printer
HP LaserJet 2200D Printer Logo
469 people viewed this question
Seeker5211
Seeker5211
