Question about Zhone (6218-I2-200) Router
Mtu setting how do i change the mtu setting on my zhone 6218-I2-200 router? I cannot seem to find out how to change the MTU setting so I can get onto Xbox Live.
    Genius:
  • 1,268 Answers
In some cases, MTU is not necessary to adjust. Its always automatic and defaulted to 1500. The router model that you have doesn't have MTU settings. You can download the User's Manual HERE. You must do port forwarding and open the xbox live port so you can play xbox live. If it keeps on telling you about MTU, you must set static IP address on your xbox's settings and power cycle your devices.
Posted on Jun 02, 2009
I want to change mtu value for paradyne
You can edit it through GUI or command line. Be careful as to what you set it to as MTU settings can really affect your traffic flow. Read the manual for help
Apr 08, 2010 | Paradyne (6218-A1-200) Wireless Router...
I need help changing my mtu setting for my 6212-13-200 Zhone router
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on WAN settings and change MTU settings then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 12, 2010 | Zhone (6218-I2-200) Router
Mtu settings
Pls give me a detail of what need to you for mtu then i can help you.
Dec 31, 2009 | Zhone (6218-I2-200) Router
Mtu Settings for the Thomson ST585v6sl
The MTU is the Maximum Transmission unit. Basically this tells the router how small to break the packets up, that it sends to your computer. When your computer downloads a internet page, it comes to it from the router in pieces. The size of the piece is the MTU. Changing it will NOT speed up your bandwidth from .5 to 3. Whatever bandwidth you get from your provider is what you have. The only thing that your router does, that can slow it down is the security key. If you have the wireless security on, then it has to verify each packet. If you need it leave it on, if not turn it off. If you turn it off, ensure you have other security measures in place.
Nov 25, 2009 | Zhone (6218-I2-200) Router
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
Router doesn't work with xbox live
The below link goes to a Microsoft Knowledge base article which addresses this issue.
http://support.microsoft.com/kb/840419
May 29, 2009 | Paradyne (6218-A1-200) Wireless Router...
MTU
MTU, Partial Loss of Internet Connection, and Performance MTU (Maximum Transmission Unit) is the largest packet a network device transmits. The best MTU setting for NETGEAR equipment is often just the default value. MTU is sometimes presented as something that can be easily changed to improve performance, but in practice this may cause problems. Leave MTU unchanged unless one of these situations applies: 1. You have problems connecting to your ISP or other Internet service, and their technical support (or NETGEAR's) recommends changing MTU. For example, these services may require an MTU change: * Yahoo email * MSN * AOL's DSL service 2. You use VPN, and have severe performance problems. 3. You used a program to "optimize" MTU for performance reasons, and now you have connectivity or performance problems. * An easy solution to most problems is to change MTU to 1400. * If you are willing to experiment, gradually reduce MTU as described in "Details of MTU", below. How to Change a Computer's MTU Size Note: If you change MTU on one computer, it is likely you will want to change it on your other computers, switches, and routers, as well. Instructions for changing MTU on other NETGEAR devices is found in the Reference Manuals. The third party Dr. TCP software can be used to change the MTU setting. 1. Download it from this link, choosing the zip file or the exe file at the top of the page. 2. Run the utility. 3. In the Adapter Settings pull down, select the Ethernet driver and adapter used to connect with the network. 4. In the MTU box, type the MTU size you are trying. 5. Click in any other box, without changing the data there. 6. Click Save. 7. Click Exit. 8. Restart the computer. Details About MTU A packet sent to a device larger than its MTU is broken into pieces. Ideally, MTU would be set to the same ? large ? value on all your computers, routers and switches, as well as on all the parts of the Internet that you access. But you cannot control the MTU on the Internet, and in practice the optimum MTU size on your LAN is related to your hardware, software, wireless interference, etc. * Tweaking MTU size may work well in one situation, but cause performance and connection problems in others. * When network devices with different MTU settings communicate, packets are fragmented to accommodate the one with the smallest MTU. * Windows XP sets MTU automatically, that is, it optimizes computer MTU for you. This Microsoft article explains resolving lack of connection to a broadband ISP using Windows XP: http://www.microsoft.com/windowsxp/using/networking/learnmore/ppoe.mspx * Once a network device fragments a packet, the data stays fragmented until arriving at the destination computer. Setting MTU size is a process of trial-and-error: start with the maximum value of 1500, then reduce the size until the problem goes away. Using one of these values is likely to solve problems caused by MTU size: * 1500. The largest Ethernet packet size; it is also the default value. This is the typical setting for non-PPPoE, non-VPN connections. The default value for NETGEAR routers, adapters and switches. * 1492. The size PPPoE prefers. * 1472. Maximum size to use for pinging. (Bigger packets are fragmented.) * 1468. The size DHCP prefers. * 1460. Usable by AOL if you don't have large email attachments, etc. * 1430. The size VPN and PPTP prefer. * 1400. Maximum size for AOL DSL. * 576. Typical value to connect to dial-up ISPs.
Feb 19, 2006 | NetGear DG814 DSL Modem Internet Gateway...
Zhone (6218-I2-200) Router Logo
1,463 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
