Question about Honda Maxus Pressure Washer MX5222
HondaGCV160 won't pull---engine seize?
I think it got low on oil. added oil. Do you have to reset the low-oil sensor? I can't get the cord to pull. Was mowing w/Honda GCV160 and it began to die...turned off and pull cord tightened up---wouldn't pull after that.... cleared away all grass/etc....blades tough to turn and pull wont pull at all now.. Believe engine seized up, as it was low on oil (hadn't changed/filled since last summer a year ago). Any way for this "non-tech" guy to fix it? JB
3 Suggested Answers
clyde2j2
  • 137 Answers
SOURCE: pull cord won't pull
I'ts a possibility that the engine has seized, remove the spark plug and look at it it will give you and indication if the engine is burned up.
Posted on Mar 24, 2009
  • 1388 Answers
SOURCE: I have a Honda GX 240 engine mounted on a walk
Remove the spark plug and make sure that oil did not enter into the cylinder. Oil in the cylinder will feel like engine is siezed. With plug remove and engine will not turn suspect more serious problems. If the rod is siezed due to low oil, it can be replace by removing the sump. No big deal and could be nice project. Before you take anything apart, check that the cable to the safety stop is actually releasing. This could also make you think that the engine is siezed.
Posted on Oct 18, 2011
Problem Starting Mower
if the brake cable does not disengage the brake all the way the pull cord will not work properly.It will seem stuck.
Apr 02, 2015 | Gcv160 Gas Engine
Following a leak of petrol in air filter and exhaust and checking float bowl, now cannot pull the cord to start it. Checked blade it was going round but not now. Cleaned debris. Could it be linkages?
Try removing the spark plug first then pull the cord while spark plug is out. The cylinder may be full of petrol, preventing it from moving.
Once the cylinder is free of liquid, you can reinsert the spark plug and try again to start it.
Apr 01, 2015 | Honda GCV160 Engine
Hi I have a brand new Victa Mustang with the Honda GCV160 4 stroke. Hve fuelled up, added oil, turned on fuel tap but it won't start. Any ideas?
Has it been sitting? Has the gas been sitting? I'm sure the carb is all clogged and gummed up with stale gas and dried ethanol. Buy a new carb, GCV160 carbs are like $20 shipped on eBay.
Dec 09, 2014 | Honda Garden
If my generator shut off due to low lubricant will it reset automatically? If not is there a reset valve/button?
The pull cord is like a starter on a car (separate from the motor/engine). If the pull cord will not turn it could be because the motor/engine is seized.
Mar 04, 2013 | BlackMax 3000 Watt Gas Generator - Powered...
I have a Troy Bilt mower w/ a Honda engine GCV160. OK, so I turned it on it's side after the last mow and the next time I tried to start it, it smoked and quit. Now the engine will not even turn over when...
Pull the spark plug and see if there is oil in the cylinder. When you turn a 4 cycle engine over or on it's side, the oil can leak into the cylinder. There may be so much oil in there that the piston won't move. When you have the plug out, clean it before you re-install. Good luck...Lee
Nov 01, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Pull cord won't pull
Mar 24, 2009 | Honda Maxus Pressure Washer MX5222
Honda GCV160 5.5 on a pressure washer runs only intermittently
The problem is the plastic float in the carburetor, it's not adjustable and after sitting up with gas in it it distorts. Save yourself the trouble and buy a new one, you can get them online for $15-$20.
Mar 17, 2009 | Campbell Hausfeld Garden
Honda Maxus Pressure Washer MX5222 Logo
1,848 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
