Question about Dryers
Not heating up
The dryer works but does not heat up. I have replaced the thermostat and thermal fuse. I checked the heating element but the coils look fine. I now have an ohm meter and I need to know what kinda of readings I should be getting. I plan on checking the ohms on the heating element, thermostat, thermal fuse, and there is another fuse or something. If you could help I would appreciate it.
  • 142 Answers
Check the wiring to the heating element and ensure all the connections are tight and there are no burned wires. The heating element should be continious with no breaks.
ohms should peg the meter if everything is good.
Posted on Jun 02, 2009
No Heat- have replaced thermal cut off, thermal fuse and the heating element with no success. Any idea what else I should check?
  • Thermal Fuse,Timer, Temperature Sensor, Coils, Gas Control Valve, Radiant Flame Sensor, Igniter, Cycling Thermostat, High Limit Thermostat, Heating Element!
  • The things listed above can all cause no heat in drying if they are not working, or working correctly!
Mar 02, 2016 | Kenmore Dryers
My dryer, a Whirlpool LER8648LW0, has stopped heating. It will turn on and run through the cycles but only blows cold air. Today I checked the thermal fuse, both thermostats, and the heating elements with...
Hi Jesse
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Bud
Oct 10, 2013 | Dryers
No heat
Hi abbey
Check your Wiring
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the heating element/thermostat/thermistor due to overheat.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
Please take time to rate me
Bud
Apr 12, 2013 | Kenmore 80 Series Heating Element -...
Suddenly quit drying. Everything works but the heating element
Hi tgs6727...
Check your Wiring
Please take time to rate me thumbs up
Sep 21, 2011 | Maytag Dryers
Will not heat, replaced heating element kit. still not heating
Hi denise bobby...
Check your Wiring
Sep 11, 2011 | Dryers
No heat . heating element looks good no coils broke. replaced thermal fuse and themostat .now what?
Hi mikedissnts...
Check your Wiring
Sep 08, 2011 | Amana Dryers
Dryer not heating checked element and all fuses
Hi kain34...
You have checked some of these but:
Here are a few more things to check:
Check your Wiring
Sep 05, 2011 | Maytag MEDE300V Dryer
My roper dryer will run but not heat up. How can I tell if its a thermal fuse I need or a heating element?
Hi shdawn24...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
You can test the thermal fuse with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
Aug 23, 2011 | Dryers
Dryer will not heat up when running. Was told to check the thermo fuse, ignitor and/or coil. Is that right? How do I check those things.
hello there
Please follow this procedure I have provided below and it will tell you how to test each one ok
Hope this is very helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Jan 24, 2010 | Kenmore Dryers
Wont heat up
Generally either a bad thermostatic fuse or an open in the coil. I would suggest checking Here:http://www.repairclinic.com/ for issues related specifically to your make and model as well as repair/diagnosis advice and parts.
Jan 22, 2010 | Dryers
Dryers Logo
106 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
