Cycle knob just hums
My cycle knob just hums but when i slam the top load door the machine begans to work, but stops working when it is time to drain and spin
    President:
  • 1,185 Answers
There is a microswitch built into the lid which stops you putting your arm in when the drum is spinning (It was put there after someone broke their arm in numerous places by doing just that )
If it is slightly out of adjustment it will need a heafty slam to get a contact but will ease back and do what it is supposed to do (Stop the spin and pump action )
If you close the lid when the room is quiet you should be able to hear a clicking noise as you raise and lower the lid if not then it needs adjusting or replacing
Posted on Jun 02, 2009
  • 142 Answers
Cycle timer needs replaced. Try first cleaning it with electrical contact cleaner. you can get that at home depot or lowes.
Washer (total care system) is making a humming noise even though I've taken all the clothes out of it. The agitator works, but there's a humming noise. I've stopped it and re-started it, but...
Hi
1 of 2 things could be the trouble.
Does the washer drain properly if you manually turn the control knob? If not then this sounds like your pump is either plugged with possible lint and can't move or has died completely. 99% chance pump is the problem and 99% chance it can be an easy fix by cleaning the pump where the Drain Line is attached, worst case scenario pump is to be replaced, but not a overall expensive fix and most can do it without a technician.
Second problem is possibly the time itself, but if the washer is going through all cycles except spin then pump is likely the culprit, cause in spin cycle the machine has to drain the water from the unit as it spins, if it cannot the washing machine basically stops and cannot complete the cycle.
One way to tell for sure if the pump is the problem. When the machine enters the spin cycle and starts making that noise. Manually turn the dial a little bit till it passes the spin cycle, if it continues to wash till it hits the final spin/drain cycle then stops again...your pump is in need of help.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Kenmore 24032\24036 Top Load Washer
My estate washing machine will not spin out, all of the other cycles work correctly.
Hello
Try to clean the magnetic door switch,some windex and a paper towell.Just do the part on the door or lid and where the lid meets the top of the magnet.Make sure this is not loose and is seated in the machine.
You may need to unplug machine and remove the door switch,take both wires and tie them togther so they make contact.Then try a wash cycle or try the spin cycle.
The door switches in the estate washers fall apart and get corroded and can stop the spin cycle.
If the machine works with the switch taken out then you will need to get a new one from whirlpool.
Mar 25, 2011 | Estate Washing Machines
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
My washer will not drain but everything else is working on it can u give me instructions?
most of the time it is the door switch that gets damage when the door slams. if its only fill with water but not turning then it is defently the door switch.
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
Washing machine stops after final rinse cycle
Your lid switch is bad. It must be replaced.
Jun 26, 2009 | Whirlpool Washing Machines
A humming sound in the cycle knob
Make sure that the room is quiet then check that there is a clicking noise from the lid when it is nearly closed
If not then the microswitch is out of whack and needs adjusting
When you slam the door down it is probably enough to make the switch but then the machines movement will undo that action
Jun 02, 2009 | Kenmore 24032\24036 Top Load Washer
No spin or agatae
Unplug machine. Change load type to medium. Clean door sensor. Set knob to drain and spin. Plug machine back in to powr. Open and close door 10 times in 15 seconds. Pull knob to activate drain and spin.
Mar 19, 2009 | General Electric WHDSR316G Top Load Washer
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
