Question about Garmin Forerunner 405 010-00658-20
Screen freezes and display faints
My garmin 405 was working briliantly until I ran this morning with a full battery charge and after 2 kilometers it just went blank! I have subsequently recharged the battery after which the display showed very faintly and was stuck on one specific time. After that I have pressed both buttons for 30 seconds and that seems to reboot it. However after a short time (10 minutes?) the display fades again and the time does not change!! I have probably done it 3 times throughout the day and am now ready to throw my watch away!!! Please help...
  • 1 more comment
  • lshlesinger Jun 03, 2009
    Thanks for your reply. I actually did exactly that! I allowed the battery to drain and then recharged it to about 50%. It seems fine. I have not trained with it yet but at least it does not freeze! If it does not work I will change the battery. Could the battery be damaged because I recharged it using a usb adaptor for a wall plug?
    I have used it on my computer's usb port this time. ( I normally do except for once or twice on the usb adapter )It is a bit tricky to discharge it fully. It could mean that you run out of battery before the end of a run! What would be the quickest way to discharge it?
  • Shannon Greer
    Shannon Greer May 11, 2010
    how old is the battery? could be a bum battery. I would start by allowing the battery to drain completely and then recharging to full. If that didnt work I'd try with a new battery
    Sniper:
  • 75 Answers
Hopefully the usb adapter just confused the battery. Did you use it this time or a regular plug? Its always best to fully discharge a battery and fully recharge it for the next use. They will lose life and malfunction otherwise. Glad you've had some luck, hopefully it will work just fine now.
Posted on Jun 03, 2009
Faint picture screen
Press the reset switch to reset the garmin, is the backlight turned off in the settings or is it possibly faulty?
Oct 27, 2008 | Garmin StreetPilot c530 GPS Receiver
Froze on garmin screen won't give directions
Could be a battery problem not having enough charge to get past the Garmin screen you might need to replace the battery or it might need to be reset.
Not knowing which model of Garmin it is makes it hard to provide a correct solution. ?
If your Garmin Nuvi 1300 is freezing up or not working correctly, a soft reset can be performed. A soft reset unfreezes the unit and brings you back to the main menu. If a soft reset does not solve the problem, or if you are selling your unit and wish to erase all of your saved information, a hard reset can be done. A hard reset restores the original factory settings to the unit. Once the information is deleted, it can not be restored. Turn on the Garmin Nuvi 1300. Press and hold down the "Power" button. Release the button when the main menu is displayed. The unit is now ready to be used. b> Hard Reset b> Turn the Garmin Nuvi 1300 off. Press your finger against the bottom-right corner of the Garmin display screen. Leave your finger in place as you power the unit on. Release your finger when the display screen asks, "Do you want to erase all user data?" Use your finger to tap "Yes." The unit will begin to reboot. Do not use the unit until the main menu is displayed. The reset process should take about 45 seconds. Hope this helps.
http://www.youtube.com/watch?v=xjUSGY7KVAk How to Replace Your Garmin Nuvi 255 Battery
Jan 04, 2013 | GPS
Change display from miles to kilometers on Garmin 405
Touch MENU then touch SETTINGS then touch SYSTEM. This gives you the option of STATUTE or METRIC. Select METRIC and it will change from miles to kilometres
Sep 06, 2010 | Garmin Forerunner 405 GPS Receiver
My Garmin Forerunner 405 is completely locked up.
In regards to the locked up Garmin: Press and hold BOTH side buttons at the same time until the unit goes blank. Once released, it should be reset...... This should not remove any history or settings.
Mar 22, 2010 | Garmin Forerunner 405 010-00658-20
Geko 101 wouldn't turn off. Removed/inserted batts, wont turn on
Press the power on button while holding OK until the unit switches on- that puts the 101 into Service mode. Then press the up key until the screen contrast is about right. (or press the down key... to make it darker). You'll be able to see if all the tests pass. Then when you're happy with the setting, turn off.
Mar 31, 2009 | Garmin Geko 101 GPS Receiver
Battery Charging, Nuvi 35
Charge the unit over night, Plug in the AC charger and you should see a lightning bolt over the battery bar graph display.
With the charger plugged in, gently press and hold the on/off power until the screen goes black and displays the text "Charging battery". After a few seconds, the screen will go black to conserve power. At any time, you can press the screen and it will light up saying its still charging.
If you let it go over night, when you touch the screen, it will say Charging Complete and you can then remove the charger. You should have full green bars on the battery indicator.
- Jim
SHARCNET-USA
Dec 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
Garmin GPS-V freezes up
The update from Garmin seems to have cured the problem!! All I did was the reload.
Thanks velomaster!
I've had my Garmin GPS V for almost four years and loved it ... until the dreaded "black line" showed up. I considered replacing the unit but couldn't find anything that would give me the features the GPS V gave me (elevation, ground speed, grade change) and I didn't need a color screen display as an alternative. I'd even bid on a few replacement units on ebay. I was just about ready to bite the bullet, send it in to Garmin and swallow the $125 rebuilt charge when I ran across this thread. After the update it hasn't locked up and as a bonus I have more detail than I had before!
http://www8.garmin.com/products/webupdater/
If you have a GPS V you really do need to do this.
Mar 17, 2008 | GPS
Garmin Forerunner 205 won't power up
Awesome! MODE + RESET works!
I woke up this morning and found I had a charger death again. It happened two years ago, and I couldn't remember what I did to fix it then.
Mar 10, 2008 | Garmin Forerunner 205 GPS Receiver
Garmin Forerunner 405 010-00658-20 Logo
1,041 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
