Question about Kyocera Mita KM-4035 Printer
Scanner doesn't see PC in address book
Scanner -- Send to PC doesn't recognize user. I changed the IP addres in the address book, go to Send to PC, Save at PC and it can't find pc.
  • kchadwell Jun 02, 2009
    I'm talking about the setup on the Kyocera KM-4035. In the address book, I have typed the pc's correct IP address, yet when I go to Scan > Send to PC > and choose that user, then go to SAVE AT PC, it says it cannot find the pc. I am scanning to other pc's.
    Does that make more sense?
  • meteshadow May 11, 2010
    start - run and type the ip \\???.???.??? like this way.
    Sniper:
  • 62 Answers
Is your scanner file utility program installed and running in the lower hand tasbar..in the file utility the scan folder number must match the one your entered into the machine
Posted on Jan 06, 2010
How do we add a designated PC to the scanner function so that the KM-1650 All-in-One-Printer will recognize it as a destination PC?
You will need to get into the machine gui. Get your IP address and type it into the address bar of a web browser of your choice. You should then be able to add a user into the address book from there.
NOTE: There are 2 NIC's with these models. One for print and one for scan. This means you have 2 IP address's. You must have the correct one to input an additional PC.
Nov 06, 2014 | Kyocera Mita KM-1650 All-In-One Printer
I need to change my ip addres, i have an acer aspire with linux
This computer as any once assigned a IP address is locked to it
Jul 19, 2011 | Acer Aspire One PC Notebook
Need to change IP address for Actiontec router for verizon fios
definately you will need to change the IP address.
But you can also change the IP address of the wireless extender.
so instead of changing the IP address of the router, you can change the IP address of the extender.
For that you will need to connect the computer to the Extender.
assign a static IP to the computer 192.168.0.10 and Default gateway 192.168.0.30. that will open the set up page of the extender.
change the IP addres of the extender to 192.168.1.30.
that will help you.
For more info about networking click Here
Oct 21, 2009 | Actiontec Electronics (GT724WGR) Retail...
Scanner doesn't send to PC
hi
I dont work on Sharp machines but this may help
If a PC or network is running DHCP it means the IP addresses are on a short lease and are called Dynamic IP addresses.
If DHCP is turned off then your PC's are running Static IP addresses which means that they will not change.
Ok...if you are running dynamic IP addresses your scan to PC destination will have to be the host name of your PC and not an IP address
eg   james.
to find out, do the following
start,contol panel,system,computer name.
hope this helps
Aug 13, 2009 | Sharp Office Equipment & Supplies
Scanner (c2520). all of the sudden, when trying to scan a document (we scan to PC...select a sender....save at user PC...and the message we are getting is:incorrect setting of destination folder. contact...
1. Use a web browser to go to the machine at the ip address that you assigned to the scanner to check the network connection.
2.you need to make sure that the computer you are scanning to has the "Kyocera scanning utility" installed and running in the background.
Make sure address book is running. In address book editor you can change the path of the destination forlder and the Id# that are linked together.
Hope this will help.
Jun 01, 2009 | Kyocera Mita Office Equipment & Supplies
Unable to create an email address on a Imagerunner 3220
Hi Keeyan.
Fist you will need a send kit only supplied by your dealer.
If this funcktion is inable follow these steps.
Press the user button(it is the button with the star)
Select system settings,network settings-in network settings go down wit the arrow until you get e-mail/i-fax settings.(If it is not showing here or in tcp/ip settings the send kit might not be enabled)
In e-mail settings enter the smtp server name or ip address(you will find it on your computer in outlook under tools and acounts)
In the email you can enter a email address supplied by your network adminitrator.
If you have a DNS server insert the ip adress of the DNS in TCP/IP settings.
Make sure you IP addres is also correct.
Then you are ready to go
Nov 21, 2008 | Canon imageRUNNER C3220 Color Copier
Changing IP address on computer with router linksy802.11b
access your router with ip.
open internet explorer if your defualt router ip is :192.168.0.1 type this http://192.168.0.1 in addres bar in IE. then neter username admin and password aslo admin
if not accepr blnk user name and passowrd is admin.
then go to ssytem then set ip and follow the procedure.
Oct 06, 2008 | Linksys BEFW11S4 802.11b Wireless...
Xbox 360 to Linksys wireless modem...
OK I think the easiest way to connect the xbox to the linksys, is if you configure your XBOX to have a static IP address, because the xbox will not have to pick an IP address every time you connect to the internet using the Linksys router and will not have conflicts with other PCs on your house, if you have any. What the linksys does is to convert your Public IP addres into a Private IP address, so example if your ISP gave you an IP address of: 209.235.205.30 that is your IP address for you, then the Linksys converts that number (NAT) into a private IP address so it can be share with many computer inside your house using a single Public IP address. The Linksys always transform it into 192.168.1.?=any number between 1-256 thats the defaults IP address from the manufacturer but you can change it if you want. Ok enough info about NAT or IP jeje.
Where going to use the default IP addres for an easier setup.
First: On your XBOX 360 dashboard go to SYSTEM, then Network Settings, then Edit Settings, then choose the option manual, here put the IP address= 192.168.1.33 (if 33 doesn't work use another numer like 20 or 45 just pick a number between 2 and 250) ; Subnet Mask = 255.255.255.0 ; Gateway = 192.168.1.1; DNS options put Automatic. And see if it connects. If it doesn't work just post it here, any problem that you have.
Aug 22, 2008 | Microsoft Xbox 360 Console
Scanner
If you go to copiers web page you will find address book in that, to axcess web page type in copiers ip address in web browser (explorer) , you can find copiers ip address by printing out config/setting page of copier or looking at print driver port setting on pc, a IP address look like this 123.123.001.023
Oct 29, 2007 | Sharp AR-M277 All-In-One Printer
Kyocera Mita KM-4035 Printer Logo
553 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
