Question about Casio Atomic Timekeeping WV58A 9AV Watch
Ironman triathlon solar
What the hell is the AC pad to be shorted with the + of the rechargeable in order to reset ?! where is it accessible under the back lid/cover, what does it look like ?!
thank you whoever you are !
    Problem Solver:
  • 19 Answers
HI Certype,
Welcome to the wonderful world of watches (my daily life and I love it).
OK I can assume you know how to take the back off of the watch?
Yes take the small black cover off the top of the battery (its actually a insulator) then with a pair of tweezers and a manifigying glass look for a the letter "AC" on the inside the watch in front of you.
When you see it you'll probably see a little gold point near it, press one end of the tweezer there gently and the other on the top of the battery and hold gently for 5-10 seconds.
Replace battery cover and you should have done the trick and back case screws etc.
Posted on Jul 15, 2009
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
Where are the two AC pads and how do I short them?
Oftentimes they will just look like brass contacts on the printed circuit. Sometimes they may have markings beside them. Shorting involves contacting both pads at the same time with something like a pair of metal tweezers, generally to reset the memory.
Aug 20, 2015 | Timex Ironman Triathlon 30 Lap #T5F821...
How do you set the digital time on the Timex Ironman Triathlon Solar Dual-Tech watch?
There are two ways to find the user manual for your Timex watch.
  1. Find your watch on the list below and click on the language link for your manual.
  2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Nov 20, 2010 | Timex Ironman Triathlon Solar Watch T5G691
After replacing a battery in a timex ironman with data link, they tell you to short the ac pad and the vss pad. Were are those points located?
You will find them on the module itself.
So after replacing the battery look on the PCB (printed circuit board) for the letters"AC" and "VSS". Adjacent to these markings there should be little contact points (probably gold or silver looking in colour)
Use a paper clip or similar and bridge (short) these two points simultaneously. Please rate my solution.
Jul 26, 2009 | Timex IRONMAN Triathlon Data Link T53722...
Help with battery problem on Timex Ironman Data Link Wrist Watch and after installing a new battery the alarm is silent.
Help with battery problem on Timex Ironman Triathlon after installing a new battery and reset, displays the message 846010 1.0 P1and the alarm is silent.
Jul 08, 2009 | Timex Ironman Triathlon 50 Lap Digital...
Problem setting my timex iron man cr2025
good morning ! try to short the reset pad on the pcb of your watch ,just open the case back and use a twisser to short the reset pad ! good luck !....
Sep 02, 2008 | Timex Sports Ironman Triathlon 100-Lap...
Ironman Triathlon Sleek Ladies watch Band problem.
try simple free or a citrus solution often found in household cleaners. js
May 24, 2008 | Watches
Setting time/date on Ironman Triathlon 8 lap
Press & hold set button the seconds will flash.
Press split/reset to set seconds to zero
Press mode to select hours
Press split reset to advance hour digits go through 12 hours to get to AM/PM
Press mode to select minutes
Press split reset to advance minutes
Keep repeatin the above steps to set month date day and 12/24 hour diplay
Press set when done.
Mar 09, 2008 | Timex Sports Ironman Triathlon 50-Lap...
I have a Timex Ironman Triathlon Speed + Distance...
The Timex Ironman manual and website says to take the watch to a repair facility. Nope! Do it yourself!
How to replace the battery in a Timex Ironman watch:
This is easier if you remove one of the rubbery wrist bands.
1. Take note of the position of the metal back cover. You'll need to reinstall it exactly as you see it in order to hear the alarm.
2. Remove the four screws that hold the metal back cover, and pry off the cover.
3. There is a round metal clip that holds the battery in place, covered with a transparent plastic cover which likely says, "Unlatch to remove battery". Within the center of each clip, there's a small opening just large enough for a straight pin to be inserted. A jewelers screwdrive won't work - use a straight pin. Insert a straight pin into the tiny opening at the edge of the clip, and wiggle it. The clip should release. You'll only need to unlatch one side of the battery retaining ring.
4. Gently pry up the batter retaining clip, then pry up the battery. Insert new battery.
5. Replace the clip.
6. Insert a flat blade screwdriver into a slot which has two "electrodes" or pins - they need to be shorted with the screwdriver to reset the watch. Just touch the screwdriver blade across the two pins to short it.
7. Reinstall the back cover but be sure to position the cover so the alarm sounding place ( a small disc attached to the inside back cover) will reside over the sounding spring.
8. Insert screws.
Dave
Oct 01, 2007 | Timex Sports Ironman Triathlon 100-Lap...
Casio Atomic Timekeeping WV58A 9AV Watch Logo
154 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
