I don't looking for setting the Jumper 3 (J3) in a motherboard PCCHIPS M812LMR for a AMD K7 with chipset SiS730S to fix my CMOS Setup.
Please, I waiting a solution or suggestion,
Thanks!
[email protected]
What's the problem? We need a bit more information than just "I'm having a problem". Please be specific about what is happening and what you're trying to fix.
Fijate en esta página que tenes los drivers de las PCCHIPS viejitas. Tenés además, que controlar que el jumper JP3 que habilita la placa de red. Jumper JP3: Enable/Disable Onboard LANUse this 3-pin jumper to enable or disable the onboard network adapter. Function Jumper Setting Enable Onboard LAN Short Pins 1-2 Disable Onboard LAN Short Pins 2-3
I have an old pc chips M575 motherboard that also uses the J3 ATX Form
card. I can only assume the pinouts are the same so here they are from
the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
You could,nt find it Because It,s listed under Archive Boards.
I think this Is what your looking For, You can also download Drivers Et,c.
Please don,t forget to Rate This Post, Once you,ve Fixed Your Problem.
