Question about Bosch MKM 6000 Electric Blades Grinder
Where can I get grinder replacement blade?
Bosch  mkm6000 coffee grinder
  • 474 Answers
SOURCE: Where can I get a
Try Craigs list USA.
Posted on Feb 20, 2011
0 characters
1 Points
Bosch Coffee Grinder KM13
This is a picture of a KM 13. This grinder stopped working and I think it was the switch that caused the problem. All I did was reassembling the switch - which consists of a thin piece of copper - and cleaned the points where the coils touch the rotor. 6_9_2012_9_54_34_am.jpg6_9_2012_9_55_08_am.jpg
Nov 14, 2011 | Braun KSM 2 Electric Blades Grinder
I am looking for a new blade for this product. Do you have them and what is the cost?
Compare the price of a new blade versus a new BURR grinder.
BURR grinders are more consistent for grinding coffee, blade grinders, you have to guess and some grounds will be finer than others.
This is the reason you don't see a BLADE coffee grinder for commercial applications.
There are some good home burr grinders (some with a timer) and not that expensive.
Jan 14, 2011 | Bosch MKM 6000 Electric Blades Grinder
How do I open my Bosch MKM 6003 coffee grinder? I can't pry it open and it doesn't have screws!
you should just a little rotate down part of the device. after that it can be taken off.
Dec 17, 2009 | Bosch MKM 6000 Electric Blades Grinder
Source for replacement blade for CBG5 B&D Coffee Grinder
Unable to find any parts supplier who offered a replacement blade for the CBG5 SmartGrind Coffee grinder, the broken plastic center spindle was reconstructed around the attachment nut, and an epoxy cement was poured around the nut and over the center of the blade.
This solution has worked in testing the blade on the grinder, but how long it will hold up has not yet been determined.
Oct 07, 2009 | Black & Decker Black and Decker CBG5...
How do you take a bosch coffe grinder apart?
Using a screw driver or the old butter, pry off the bottom piece.  Be careful though, getting it back together is really tricky if you don't pay attention to where all the parts go.
Feb 05, 2008 | Bosch MKM 6000 Electric Blades Grinder
Blade replacemen braun grinder
Insert a small standard screwdriver in the slot in the center of the bottom. Turn the blade slowly until you feel the screwdriver catch in the slot. This holds the motor still so you can simply unscrew the blade counter-clockwise. Do the same to hold the motor from turning while you screw the new blade on clockwise.
Dec 16, 2007 | Braun KSM 2 Electric Blades Grinder
Bosch MKM 6000 Electric Blades Grinder Logo
115 people viewed this question
Top Bosch Coffee Grinders Experts
Ernest R
Ernest R
Tony R.
Tony R.
Are you a Bosch Coffee Grinder Expert? Answer questions, earn points and help others
