Question about Pioneer TS-A6962R Car Speaker
Remove rear headrest
Tryin to remove rear headrest from my merc 320clk so i can take the parcel shelf out
  • 518 Answers
NORMALLY THERE IS A SMALL SLIDER JUST ABOVE THE SEAT WHERE THE HEAD REST SLOTS INTO, PUSH THIS IN ON BOTH SIDES IF THERE ARE TWO AND THEN IT SHOULD RELEASE
Posted on Jun 13, 2009
How do you remove rear speaker covers in a 96 geo
are they fitted in the rear doors or the parcel shelf ,if there aree no visable screws to un do if door fitted then will have to remove the door panel , if on parcel shelf same thing if no screws visable then remove from underneath , hope this is of some help
Sep 29, 2014 | 1996 Geo Prizm
Where is the parcel shelf on a 2007 Mini Cooper
The parcel shelf is that flat area behind you head of the rear seat. Normally has speakers or junk on it. On hatch back cars it lifts up as you open the hatch.
Mar 28, 2013 | 2007 Mini Cooper S Convertible
How to replace the third brake light bulb on 2005 ford five hundred
  1. Remove the parcel shelf.
  2. Remove the 4 high mounted stoplamp mounting screws.
  3. Remove the high mounted stoplamp.
  4. To install, reverse the removal procedure.
Parcel Shelf Removal and Installation
Sep 05, 2012 | Ford Five Hundred Cars & Trucks
How do you remove the rear speakers from a 2004 chevy impala?
Remove the rear seat. On later models remove the rear upper quarter panel by pulling down & out to disengage the retainer clips, then sliding the roof leg out from under the trim panel over the door. Detach the rear seat belts through the slot in the rear parcel shelf. Pry up the plastic clips securing the rear parcel shelf. Then lift up & out to remove it from the vehicle. Remove the speaker retaining screws or tabs. If the speaker seal has bonded with the metal shelf, hold the tabs & pry the housing away from the metal. Disconnect the electical connector & remove the speaker. Install in reverse order. Good luck!
Feb 22, 2011 | 2007 Chevrolet Impala LS Sedan New Cars
How do i open Jaguar x-ype boot from inside.
It is possible to open from the inside, but causes a little bit of (hidden) cosmetic damage, so only do this if you have to get the boot open because it is completely jammed shut.
Remove the headrest from one of the sides of the back seat. I used the side where the smaller part opens when folding the seats down, but I would suggest you use the other side as once you get the seat down you have a bigger opening to let you get the other side down too.
The parcel shelf is in 3 parts, a wide centre part and 2 small endpieces which carry the slots for the seatbelts. Once the headrest is removed, insert a screwdriver into the join between the end-piece and the center part of the shelf, and lever the end-piece up an inch or so, grasp it and pull it up enough that a couple of clips disengage. Then, you will see that the centre part is now a loose fit. Next, using a sharp knife, a Stanley knife or similar, cut the centre shelf from the outside edge towards the middle, for about 30cm. Make this cut as far down at the back of the seat, and when you put it back and the headrest is reinstalled it will be invisible (well, almost)...the neater the cut, the less likely it will be seen afterwards.
Next, peel the centre shelf towards you, away from the rear window, until you can see a hole in the metal sub-shelf below. Ignore the two round central holes with cloth covering, but go for the elliptical hole near the side of the shelf.
Remember what the seat-back release cables look like in the boot? Held up with clips either side, the cables have a ribbed rubber sheath. Stick your hand in the hole into the boot and locate the cable. It will not be possible to unlock the seat release because the knob is out of reach (unless you have VERY long, bendy arms) but the clips are nt very secure, so just grasp the cable wherevr you can and pull hard to diislodge the clip. The cable will come away from its retaining clip, or actually, the clip will pull out of its housing and then you can simply fish the end out and release the seat-back.
Next, reach in and yank the other cable out too, or, if you can release the other seat-back easily in the normal way that would be better!
Now you can crawl into the boot.
With a screwdriver, remove the plastic cover that covers the boot-lock mechanism. A good torch is handy here! The 2 visible screws come out ok, but you will probably have to yank the cover off since you cant get at the bottom edge to ease it over the lock. Don't worry, it will split open, and can be popped back on later with no difficulty, just a small split in the plastic.
Finally, looking at the exposed lock, you will see a little lever with a hole in it, on the left hand side as you face the back of the car. Simply flick this up with your finger and the boot will open.
OK, it sounds complicated, but actually it took me just 20 minutes, 10 of which were used up trying to decide whether or not to cut the parcel shelf!
My mechanic has now fixed the problem so my boot opens as normal now, but I don't know what he did yet as he has gone on holiday and didn't tell me what had gone wrong, but it was certainly an electrical problem. However, his list of parts used lists only wire and terminals, so I don't think the solenoid was broken, just not getting power.
Anyway, until you get it fixed, just leave one of the rear seats unlocked, and you can crawl in and open the boot anytime.
Hope this helps! Colin
Nov 09, 2010 | 2005 Jaguar X-Type
How to remove the rear speaker panel for a 1997 dodge neon
Remove entire rear seat assembly
Pry out the rear portion of the seat belt trim bezel.
Partialy remove the rear parcel shelf trim panel, slide it down and out of the way.
Remove the screws and detach the speakers.
Installation is reverse of removal, making sure that wire connectors face toward the center of the vehicle
Dec 30, 2009 | 1997 Dodge Neon
How do i get the back parcel shelf out of my bmw 530d so i can tint the rear window? and also the back seats to get the parcel shelf out ?
Why do you need to remove the parcel shelf and the seats just to tint the window?
If you are using film tint lay it on the outside of the window cut it a little larger than you need it. Clean the inside rear window then use a squirt bottle with soapy water in it spray the window roll out you tint using a squeegee to remove air pockets. Finally trim the edge with a razor blade window tinted.
Aug 31, 2009 | 2002 BMW 5 Series
Honda Accord brake light removal
It's a lot of work for just cleaning.
Fold the rear seat down and remove the two 12mm bolts on the bottom corners of the seat back, pull the seat out.
Between the seat bottom and the carpet you will find two tabs you need to pull and then pull the seat bottom up and out of the car.
Remove the two 10mm bolts securing the seat bolsters to the area the seat bottom was covering. Pull the seat bolsters up and out of the car.
Pop the "C" pillar trim off of the car (above the parcel shelf and beside the rear glass) (side airbag vehicles have a slightly different procedure.)
Pull up on the parcel shelf carefully and evenly. Remove clean and put everything back together.
Aug 16, 2008 | 2005 Honda Accord
Changing Rear Speakers in a 1996 a4.
First remove the rear seat bottom cushion (grab the front edge roughly in the center of each seat position and pull up firmly, and it'll unclip and come out). Then fold down the rear seatbacks. Now, the side bolsters for the seats (between the seatbacks and the doors) have to come off. First, pull down strongly near the bottom (there's an upward-facing hook there that clips onto a ring and holds the bottom in place). Pull down and forward and it'll come off. Then slide your hand about 75% of the way up, and pop the bolster straight forward to pop out a retaining clip. Finally, you can remove the top of it from its mount, and you'll have the bolster out. Repeat for the other side.
Go into the trunk and look up at the bottom of the rear shelf. The harness plug for the third brake light is there - unplug it.
Now, back in the rear seat area, just grab the front edge of the parcel shelf and lift upward to pop it loose, and the whole thing will slide forward. Then you can remove your speakers.
Install is the reverse of disassembly.
Jul 30, 2008 | 1996 Audi A4
Pioneer TS-A6962R Car Speaker Logo
77 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
