Question about Polaris Pb460 Polaris Booster Pump Replacement O - Ring
When running it makes a loud noise
When pump is running it makes a loud continuous whining noise
    President:
  • 1,378 Answers
Your bearing are failing. Replacing them and the seal at a local electric motor repair shop will likely cost around $50.
Posted on Jun 14, 2009
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: when running it makes a loud continuous loud noise
FFBD2411NS makes loud whining noise after water is pumped out and continues until pump stops.
Thank you for your inquiry, Robert!
From the information you have provided your Frigidaire dishwasher makes a whining noise after the water has been pumped out. This could be a potential issue with your drain pump or motor. To pinpoint the issue you would need to disassemble your dishwasher and test each component and this would best be done with a certified technician. This will help you avoid personal injury or future problems. Best of luck! -Matt
Jun 13, 2015 | Frigidaire FFBD2411NS
As soon as the motor starts up after the dishwasher fills, the motor makes a loud grinding noise that turns into high pitch whining. Water begins leaking from above the pump.
That shows a leaking water seal. Water would run into the motor bearings which then rust and make noise. You probably need the motor / pump kit.
May 20, 2011 | Dishwashers
Insalled new fuel pump on 92 pontiac sunbird, fuel pump making loud whining noise all the time, car runs fine.
Hi!!
Defective fuel pump, it happens sometimes, remove pump and replace it before you warranty runs out. It will eventually fail.
Don't forget to rate this post!!
Sep 29, 2010 | Pontiac Sunbird Cars & Trucks
I have Hayward Centurian SE 2 hp pool motor pump,around 15 years old. Just the other day it started making a loud whining noise. Is there a quick fix for this?
if its whining but still spinning, the bearings are done. If it just makes a loud noise, the capacitor could be bad or the bearings have seized.
Jul 04, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
When running it makes a loud continuous loud noise
Jun 02, 2009 | Polaris 380: Polaris Booster Pump
Loud whining noise
check alternator bearings for noise
Apr 09, 2009 | 1999 Dodge Intrepid
Continuous "whine" @ 1500 RPM only; and jerks/2001 Lincoln LS
Run the car from the top of a hill and let it coast at your whining speed. Put it in Neutral, does the whine disappear?
If not its in the drivetrain (wheels, driveshafts, tranny)
Very unlikely to be the timing belt. If it appears at a fixed speed then its drivetrain, if it whines at fixed revs its the engine.
Most likey the transmission I fear....Tires will also make loud whining noise too though...
Jan 08, 2009 | 2001 Lincoln LS
Whining
lean washer back against wall ..pump has 2 clips holding it on and 2 clamps holding hoses on ..you may try running machine with pump clamps removed and pump pulled off motor shaft first if noise diappears continue remove hose clamps and take pump completely off clean pump if possible something is probably stuck around or behind impeller if you can't find anything but are sure it's pump problem call service ..you want to use that warranty that comes with machine
Aug 29, 2008 | Admiral AAV7000A
Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Polaris Pb460 Polaris Booster Pump Replacement O - Ring Logo
1,558 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
