Question about Refrigerators
Water in bottom of "fridge" and in vegetable bins
There is water collecting in the bottom of the "fridge" and in the vegetable bins. We have taken the "floor" out of the freezer compartment and melted the ice that formed there once when this happened and it seemed to solve the problem at the time. However, the problem has returned. What should we be doing.
    Novelist:
  • 103 Answers
Hi: I'll assume this is should be a frost free freezer. If so the defrost drain is clogged and the water isn't getting to the evaporator pan. Without knowing the specifics although it sounds like a top freezer. Look for a drain below the evaporator coils. The will be in the back of the freezer behind a panel. Some models have a drain hose behind the ref. Use a strong solution of clorox and water to clean it out. The parts list or diagram of the fridge will help you find the drain. If you don't have it enter your model no. at sears.com parts direct. I hope this helps, Jeff
Posted on Jun 03, 2009
Water collecting and freezing behind vegetable drawer left side of GBSCOHCXFRWW
blocked drain.
pull the fridge out and look at the back. somewhere (unless it has cover panel) you should see a small hose. this is the drain tube. blow through this and you will most likely feel it clear out a bit. then open the fridge. good chance there could be a bit of a mess to clean up
May 18, 2014 | Refrigerators
Sears Kenmore refrigerator 18cu frost free. Water constantly flows down the back of the fridge and collects under the vegetable bins. How do I fix it?
sounds like the drain pipe is blocked. turn it round and at the bottom there is a pipe check its not blocked. to clean out use an old curtain wire or something that can get up the pipe and flex.
Nov 03, 2013 | Kenmore Refrigerators
Water is collecting on the left side on shelves and vegetable bin
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | Whirlpool Refrigerators
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Water accumulating in vegetable bin on model
This is caused by a clogged drain tube or the door is not closing correctly. Be sure the seal around the fridge door is closing correctly. If not, the drain tube needs to be replaced or cleaned.
Nov 06, 2009 | Admiral Refrigerators
Water accumulation underneath the bottom vetable
Two solutions
1 If a frost free fridge/freezer - ice build up in internal cooler - defrost totally until no more water
2 if ordinary fridge/freezer look inside at the back, you should see a very shallow 'V' shaped plastic channel running to a small drain hole which leads to the rear outside of the unit. This channel collects the water drips from the cooler
Clear this hole with a pipe cleaner or cocktail stick or similar
Sep 27, 2009 | Samsung Refrigerators
Water collects in bottom of refrigerator under fruit/vegetable bins
When a fridge goes in to defrost it melts the ice on the coils in the interior of the freezer. Often times there is a drain that runs to a sliding tray under the fridge. If this is clogged you will get water building up under the bins.
Jul 10, 2009 | Refrigerators
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Refrigerator collects water at bottom, under the vegetable/crisper drawers, needing to be sponged out daily This fridge is a 17.7 cubic ft. no frost TBX18BG
at the top of the fridge section at the center back there is a drain assy/ tube for defrost water to exit the unit and go to the bottom of the outside, this is most likely clogged up. disassemble and clear drain line, hook back up and call me in the morning.
Mar 29, 2008 | Refrigerators
Refrigerators Logo
281 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
