Question about Siemens WTXD5300US Electric Dryer
How do I turn of the anti wrinkle option
How do I turn off the anti wrinkle on my Siemens dryer wtxd 5321
Siemens dryer manual
Either a bad sensor, or control board. Cannot really fix yourself without electronic diagnostic equipment; (specialized for Siemens appliances).
Jul 18, 2014 | Siemens Dryers
Purchase Olay Nutrients Anti Wrinkle Daily Lathering Cleanser
I know this doesn't answer your anti wrinkle question 100%, but Derma Active is offering a free trial of their anti Wrinkle cream.
http://bit.do/DermaActive Derma Active Cream Best Wrinkle Cream Best Anti Wrinkle Cream For Women
Apr 30, 2014 | Olay Nutrients Anti Wrinkle Daily...
Dryer turns back on after cycle is complete
Mike, this is a anti-wrinke function of the dryer. You can turn this function off. Without a full model number I can only tell you to refer to the owners manual to disable the anti-wrinke function.
Apr 20, 2014 | Bosch Vision 500 Series Front-Load Washing...
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
The dryer is showing anti crease on the LCD. What can i do to reset or fix the problem.
have you tried disconnecting the power for about 15 minutes to see if it clears
anti crease refers to the dryer continuing to tublme for about 10-15 seconds every 5-10 minutes so when cycle is complete the clothing doesnt just set there where wrinkles can set in ,it tumbles after end of cycle to prevent wrinkling
Jul 22, 2011 | Miele Novotronic T1515A Electric Dryer
My 9800 keeps on turning on and off after cycle
That is normal. It is an anti wrinkle feature. it will continue to tumble your clothes with no heat for 30 seconds every few minutes for several hours until you open the door, or it times out. That is why you paid so much for your dryer. It does alot of cool stuff.
Mar 17, 2011 | Miele T9800 Electric Dryer
Following the permanent press cycle the dryer goes into wrinkle free mode. This mode seems to stay on for a long time. Is this normal? Thank you. Model #DV350AE
Wrinkle Free is designed to keep running so that unattended clothes do not wrinkle.
You can turn Wrinkle free off.
Feb 20, 2011 | Samsung Dryers
My dryer panel is turning on by itself. when I shut it off, it turns back on after a while. A load of clothes is drying, and the dryer keeps making a beeping sound every now and again. It seems to be...
Many of your better dryers have an anti-wrinkle function. When a load is complete if you don't take care of it, every little while the dryer will turn on for a few minutes to fluff the clothes and beep to remind you.
May 31, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a 5321-21 and it doesnt hammer milwaukee
If everthing turns on and there is no grinding in the gearbox, the unit most likely need and overhaul. Any Milwaukee service center will be able to perform an overhaul for you, or they can sell you a tuneup kit that has all the parts you need.
Jan 09, 2010 | Milwaukee 5321-21 Rotary Hammer
Dryers Logo
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Craig Butler
Craig Butler
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
