Question about Turbo Air 49 cu. ft. / 1388 liter Commercial Freezer MSF-49NM
Msf-49nm will not stay below freezing!!
Every now and then the freezer temp. starts to rise and holds around 20 degrees Faren. It will not go down even though we cleaned the condenser. The darn thing still tries to defrost even though the food inside is not frozen. We are out of warranty and have to call a tech every time. Is this a common problem and how can we get it back to the negative tempuratures? Thank you for any advise or help.
  • nemo_tone Jun 03, 2009
    First, thank you for your brilliant response time. Same day! Much appreciated. When I say once in a while, I would have to say about every 3 weeks to one month.
  • Dennis Boxerman May 11, 2010
    http://www.turboairinc.com/TB-Service/Om...
    Try this web site. It is a manual on your unit.
    When you say the temp goes up every once in awhile, do you mean once a week, once a day, or more frequent. Let me know as this does tell me some thing.
  • Turbo Air Master
  • 1,253 Answers
My next question is, you say you have to call a tech to come out. Is he doing something? And if so, what? With the limited info I have at this time, it sounds like there may be a refrigerant problem. Let me know so we can continue. Am looking forward to resolving this.
Posted on Jun 05, 2009
How tro restart my digital freezer?
Can you hear the compressor start? If not try the extreme freeze button. Check the condenser is clean and fan working ok.
Jul 24, 2012 | Frigidaire Freezers
What's your problem?
Look around for where the unit receives temp input. Maybe the sensor is iced over and reading incorrectly.
Jan 05, 2012 | Magic Chef Freezers
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
FREEZER WILL ONLY PULL DOWN TO 12 DEGREES
start simple. be sure that the condenser coil is clean. you should be able to see all the way thru the fins. verify that the evap fans and the condenser fans run. make sure nothing blocks air flow inside the conditioned space and around the condenser coil and compressor.
Let me know if we need to go further.
Apr 12, 2010 | Delfield Freezer Series 6000XL Remote Half...
Temp changes in freezer
If the temperature fluctuations occur (at least the ones to 20-30 degrees) at intervals of 6 hours or so then you are catching it in it's defrost mode which occurs on a timer. The timer shuts off everything except lights every 6 hours for an average of 20 minutes. This usually isn't enough to thaw things but I have seen it cause some crystale. Look closely at the back inside wall of the freezer for an accumulation of frost. If you see it there then you may have a defrost problem. Usually this is accompanied by steadily rising temperature in the freezer and fresh food secions both. The temps you listed (0to10) are fine. Good luck, AJ
May 22, 2009 | Freezers
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Turbo Air 49 cu. ft. / 1388 liter Commercial Freezer MSF-49NM Logo
185 people viewed this question
Top Turbo Air Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
marlin siecinski
Are you a Turbo Air Freezer Expert? Answer questions, earn points and help others
