Question about Baumatic F60 Stainless Steel Kitchen Hood
Extractor fan works, but no lights (this followed the removal of an old bulb, which broke during removal and caused a small 'bang'). Yes I know I should have isolated the unit before trying to change the bulb !) As there is power to the fan, it can't be the fuse in the switched socket .... any suggestions ? Thanks.
5 Suggested Answers
SOURCE:
  • 1462 Answers
SOURCE: Light blown then fan doesn't work!
take out switch assemby and check if the track of the pcb is blown - caused by the bulb goiung. you can often repair by soldering in wire links. bet you have 12a fuse in system - should be 3a. track has blown instead of the fuse
Posted on Mar 31, 2007
Richie_asg1
  • 1036 Answers
SOURCE: The extractor on my Baumatic
Sounds like it was the main fan motor - that caused the lights to blow in the first place.
Isolate from supply, and get the fan motor checked out. If it is burnt out (inside) you will need a replacement.
Hope this helps.
Posted on Jun 11, 2008
  • 203 Answers
SOURCE: baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Posted on Nov 22, 2008
SOURCE: The light blew on my
Look at the instruction/installation manual.
Are the bulbs 12volts or 120vac? If it is 12v there is a transformer that might be shorting to ground. If no transformer, the control panel or the control board has a short.
Posted on Mar 19, 2011
...please tell me, the small light of my old fridge broke..is there danger of fire..the fridge works..thank you..
unplug the fridge so there is no danger of electric shock,and remove the piece of socket left in there from the old bulb with a insulated pliers.. the remaining wire pieces can short out and blow the breaker in the house .i would not leave the broken bulb in there .
Feb 23, 2015 | Cars & Trucks
I have moved into a property with a Sector extractor fan in the bathroom - when you turn the light on the extractor starts up -when you turn the light off the extractor continues to run for a long time -...
On some Bathroom extractor fans there is a setting for the amount of time you want the fan to stay on after you turn off the switch, the setting dial is normally at the back of the fan so you need to take the fan down from the ceiling making sure the fan is electrically isolated.
Mar 31, 2011 | Home
Light bulb broke off in fan light how do I remove?
If the glass is broken and there are sharp pieces sticking out you can use the potato trick. Cut a small potato so you have a flat end, make sure the power to the fan light is turned off, and push the potato onto the broken remains. Then you can turn the potato to unscrew the base and just toss the whole thing in the trash. Wipe off the socket and you're set for a new bulb.
If the old bulb broke off clean so that only the base is left in the socket, you'll need to bend the edge of the base inward a little with a small screwdriver. Then grab the base with needle-nose pliers and unscrew it from the socket. Again be sure the power is off before working on the light.
Mar 15, 2010 | Hampton Bay 48670 Flemish Pewter Finish...
I heard a small bang when from the engine this morning and now the battery light is continually on - do you know what that signifies please? Other symptoms, possibly conincidental. One of the indicator...
That small bang you heard was the radiator belt.It runs the alternator(battery charger)and also the water pump.The fan belt on your motor needs to be replaced NOW.Otherwise you may blow up the motor.It doesn,t take long.Hope this helps
Dec 08, 2009 | 1996 Volkswagen Golf
My Bathroom Extractor Fan does not work properly and for some reason the bathroom smells of cigarette smoke when the upstairs neighbours are at home!! Our landlord say's this is not possible!!!
Yes, very possible!. The bathroom fan is connected together, and the upstairs one is down-drafting to you. Have the exhaust checked for blockage, or buy a fan that has a built-in damper that closes the exit when not in use.
Oct 21, 2009 | HP Extractor Fan Kit 110V Rack Mount Fan
Wireing a bathroom extractor fan to a three switch (fan=landing light=offswitch0
yes, if the three switches are all made together, then there is only one feed. sounds like a bad switch, or possibly bad exhaust fan. check voltage at fan with switch on, if not qualified, be careful, or call an electrician
Aug 10, 2008 | Dryers
Neff extractor fan not working
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Baumatic F60 Stainless Steel Kitchen Hood Logo
93 people viewed this question
Top Baumatic Kitchen Ranges Experts
Norman Al-Anbar
Treefrog15
Treefrog15
ray gallant
ray gallant
Are you a Baumatic Kitchen Range Expert? Answer questions, earn points and help others
