Question about Gigabyte Computers & Internet
PC won't start due hard drive power wire
Hello.
I'm having a problem where my PC won't start if I plug in a SATA hard drive's power wire. With out it everything works fine.
When I turn PC on the lights blink for 1 second, but then just shuts down.
Tried connecting the hard drive to another computer(with different wires and connectors) and got exactly the same result.
I understand that the hard drive is damaged, but is there any way I can get the data of it? The connector on the hard drive it self looks perfectly fine.
Thanks!
  • 479 Answers
infact there is some problem with the power circuit of the hdd so this is not possible by diy and if data is so important then the expert will take out the media and recover it.because if u will connect it with any power supply it will cut off because of the short circuit
Posted on Jun 02, 2009
3rd SATA Hard drive can't detecte.
is the sata port activated in bios?
Feb 22, 2013 | Computers & Internet
Problem with COMPAQ DC5850 SFF ATH/5000 2GB80GB COMBO WVXP PC Desktop hp compaq dc5850 pc won't turn on after plugging in old hard drive for transfer Posted by Author imageGuest on 1/4/2013
The h3ll you say.
(Kidding around)
Let me see if I understand this straight;
You unplugged THE harddrive to your computer..............
Then you plugged an old harddrive in, and expected to be able to use it.
Expected to because you've done it in the past.
Really
Curious;
1) Was it an old harddrive you had in the computer, removed it; and had a larger one installed?
2) Is it one that you have had in another computer?
Here's what I know, and why I'm asking;
When Windows is installed on a computer it assigns hash values, to certain major hardware components.
For example;
A) Processor
B) Motherboard: To include the motherboard chipset, and BIOS program. (To include version and date)
C) Harddrive
D) Graphics chipset
Change any two of these hardware components, and Windows will think it is being stolen. Put on another computer.
Microsoft User's License states, "One GENUINE copy of Windows per ONE computer"
(Microsoft makes one Master disk, and from it all GENUINE copies are made, and sold to the consumer)
Now if you stated you installed the old harddrive as a Slave drive; then I could understand.
P2 connector?
That is a Power Supply power cable.
According to specifications the Harddrive is a SATA unit.
http://h10010.www1.hp.com/wwpc/ca/en/sm/WF06b/12454-12454-64287-3328896-3328896-3658105-3687950.html?dnr=1
Internal Drives - Hard disk controller -SATA 3.0Gb/s NCQ SMART IV
The power cable to it is a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Probably what your P2, and P3 power cables are.
http://www.ebay.com/itm/HP-DC5850-SFF-Motherboard-SPS-461537-001-/310417711958?pt=Motherboards&hash=item4846566356
P1 will be a 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
P4 cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
P5 cable, MAYBE, (Might be P3 too)
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
And P6 power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
This type of power cable is also used on a Card Reader.
To conclude;
A) SATA harddrive has to have a SATA power cable, and SATA data cable.
The SATA power cable's connector is wider, than the SATA data cable's connector.
15-pins for the SATA power cable connector; 7-pins for the SATA data cable's connector,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
The above is a general example of a SATA data cable, and it's respective connector on the motherboard.
Your SATA data cable connectors on the motherboard, are of a different style than the above.
You have Four SATA connectors on the motherboard;
1) Light Blue
2) Orange
3) Dark Blue
4) White
Regards,
joecoolvette
Jan 04, 2013 | HP COMPAQ DC5850 SFF ATH/5000 2GB80GB...
My dard disc wont detict
When installing a new hard drive, a PC may not recognize the hard drive. Incorrect cable installations, jumper settings and BIOS settings may cause the computer to be unable to detect your hard drive. Due to the vast differences in hard drive types (IDE versus SATA) and brands, motherboard brands and types, and BIOS types and configurations, please download or acquire your motherboard and hard drive manufacturers' documentation prior to acquiring a hard drive. Make sure that the type of hard drive you plan to purchase is compatible with the motherboard.
Shut down the computer. Unplug all cables and peripheral devices. Clip the anti-static wrist bracelet to a metal object, and attach the bracelet to your wrist. Remove the computer's side panel. (Cases vary. Some will require a small Phillips screwdriver for removal and others feature screwless designs. Please see your case manual if you are unsure.) Locate the newly installed hard drive. Check that two cables are running from the hard drive to the motherboard and to the power supply. If you see only one cable or if either of the cables are not securely seated, plug in the appropriate connector(s). Leave the case's side panel off for now. Reconnect the power cable, monitor cable, and keyboard and mouse connections. Restart the computer. Enter your BIOS immediately. (Your BIOS usually alerts you to the key required to adjust settings. If your screen does not show this information or if you are unsure, consult your motherboard manual.) If it is an IDE hard drive, enter the IDE settings. The BIOS should show the hard drive. Configure it as primary or secondary, according to your computer's configuration. (If you have only one drive, set this to primary. Otherwise, set as secondary.) Save your settings, and exit the BIOS. Once you are certain that the the PC is recognizing the hard drive, replace the side panel. Detect a SATA Hard Disk If you have connected a SATA (serial ATA) hard drive to your computer but are not able to access the files on it, then your system may not be detecting the drive correctly. On either a PC or Mac computer, you can manually detect and mount a hard drive that is locally connected. Once properly detected, the drive will become available for file transfer.
Plug the SATA hard drive firmly into your PC computer and ensure that the drive is powered on. Open the Start menu and click on the "Control Panel" icon. Open the "Administrative Tools" folder and double-click on the "Computer Management" icon. Go to the "Disk Management" tool on the left side of the control panel window. This brings up a list of all drives currently connected to your computer. Right-click on the SATA drive that you want your computer to detect and choose "Change Drive Letter and Paths." Click on the "Add" button and then select the drive letter that you want to be assigned to the SATA hard drive. Click "OK" to save the settings and detect the SATA drive. b> Mac Instructions b> Plug the SATA hard drive firmly into your Mac computer and ensure that the drive is powered on. Open a new Finder window and navigate to the "Utilities" folder, which is located in the "Applications" section of the Mac hard drive. Double-click on the "Disk Utility" icon. Highlight the SATA hard drive that you want your computer to detect from the list of connected drives on the left side of the window. Click on the "Mount" button at the top of the window to have the system manually detect the SATA drive. Hope this helps.
Dec 29, 2012 | Seagate Barracuda 80GB SATA 2MB HDD 80 GB...
My computer doesn't recognize my optical drive within the BIOS or windows (HL-DT-STDVDRAM GT31N ATA Device ) in windows7
If BIOS won't detect the Optical Drive, try reseating the SATA cable connection from the ODD to the mainboard. it might be have troubles detecting it due to a loose connection.
May 04, 2011 | Hitachi Computers & Internet
I have a 500GB external drive that when plugged into computer, a messege comes up that says, ' One of the usb devices has malfunctioned and Windows does not recognize the driver and to try plugging it back...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 08, 2011 | Western Digital WD HDD 500GB SATA 25"...
How do i install a wdeads hard drive? where is the power supply (4pin Molex)?
I'LL TELL YOU UPFRONT i HAVE ONLY INSTALLED SATA ON A NEW SYSTEM SO MY ANSWER MAY NOT BE CORRECT IN ALL SITUATIONS
Question is vague. Are you replacing a drive or building a new system? SATA drives have a dedicated plug on the Mother Board. Of course you already know you can't replace an IDE with a SATA without an adapter (Ebay has them for about $8) or the Bios is incompatible. The power is on the Motherboard and does not have a connector from the power supply like an IDE has.
Feb 20, 2011 | Western Digital WD15EADS 1.5 TB SATA Hard...
Child has plugged in laptop extension by mistake and now it won`t turn on,is it repairable as 120 photo files are on it
You could try removing the drive from its housing then plug it into a working pc's secondary hard disk slot, it may be just the casings's power supply which burned out. Alternatilvely buy a usb to ide or sata lead and plug the drive into an old pc power supply. then plug into a working pc via usb.
Mar 25, 2010 | LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB...
My laptop is broken and i want my data copy to my other pc
Maybe you need laptop drive enclosure? It can be powered by USB cable alone together with to and in data transfer.
Hope this helps.
Jan 18, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
93 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
