I receive message "Scanner Failure Unable o scan or copy" on start up of my c6280. I have reloaded software, plugged and unplugged everything, tried the OK and Cancael button,and the OK and HELP button. Otherwise the machine works fine. I only about 500 prints on the machine.
  • 13,433 Answers
Are you still on the warranty period? its 1 year warranty from HP. (One-year limited hardware warranty backed by HP Customer Care, service and support; one-year technical phone support)
In or out of warranty, follow this page and if the problem doesn't get solved theres the contact hp link on the bottom to get hp service and support for the product.
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=uk&docname=c00587971
On warranty, its going to be completely free for you, maybe shipping charges if you have to ship it, outside of warranty they will most likely bill you for it.
Posted on Jun 02, 2009
My printer has new carthridges prints from computer but does not make copies
Try scanning from MS Paint or Acrobat & see if it works. If it does, the HP/Vista software is probably at fault. If not, the scanner is probably faulty.
Did it ever work or did you just plug it in? (Did you load the correct drivers?)
Apr 22, 2014 | HP Photosmart C4400 series
My HP Photosmart C6280 All in One will not scan or copy.....it comes back as unable to scan or copy. I have reinstalled the full feature software
Its not software issue,for copying you need not required any software just plug in power & take copy, if copy is not happening, its definitely printer faulty only..
Open flat bed, check scan head,mechanism & cable,if found any breakage in mechanism,scan head or cable, replace it & check..If its difficulty for you submit unit in service center..
Dec 06, 2011 | Office Equipment & Supplies
Hi: I have a 'all in one' HP C6280, and a HP scanjet 4010. They don't want to co-operate. Now I find that I really need to use the G4010. (I had just stopped using it). At first I thought I should...
Go to the Device manager and delete ( not only uninstall ) driver for G4010 .
Now unplug unit . Go to Controm Pannel \ programs and delete the software . You can also and preferably use a cleaning tool such as Revo Uninstaller .
Reboot but do not connect scanner yet . Reinstall software driver .
Reboot and wait for OS to be settled .
Connect your scanner and wait for confirmation of successfull operation It should work now , presuming you haven't changed your OS since before .
Regards .
Dec 29, 2010 | HP Scanjet G4010 Flatbed Scanner
When attempting to scan document or copy a document on Photosmart all in one seriers I receive an error message "Scanner failure unable to scan or copy"
try to remove and re install driver, and look into device manager if scanner detected. if not restart you pc and when found new hardware popup browse driver manually.
Apr 10, 2010 | HP Photosmart 3310 Printer
Message says "Scanner Failure" and "Unable to scan or copy"
Obviously its scanner error,the whole scanner assembly needs replacement.It could be the bulb or the scanner board, but upon replacing it needs both.
Sep 17, 2009 | HP Photosmart C5280 InkJet Printer
Hp 750xi scanner failure
Try the hp site:
I was having the same problem but ended up being able to scan using Windows Photo Gallery and my HP 750xi. Good luck!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&dlc=en&cc=us&lang=en&product=58917#Workaround
Dec 04, 2008 | Office Equipment & Supplies
Scanner failure message.
Scanner Failure, Power Off and On' Message Displays on the Control Panel when Copying or Scanning
Issue
The message 'Scanner failure, Power off and on' displays on the control panel of the product.
This error usually occurs when trying to scan, to make copies, or during the product start up.
Try the solutions in this document until the issue is resolved. It is not necessary to continue to the next solution if one solution resolves the issue.
Solution one: Check the scanner light
Make a color copy of any document by pressing the Start Copy Color button on the control panel. While the product is making the copy, slightly lift the scanner lid to see if the scanner light is visible.
CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
If the scanner mechanism moves across the scan bed, but the light is not lit, click here to service the product .
Solution two: Check operating conditions
Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product.
Solution three: Check the power connections
1.
Make sure that the product is connected directly to a grounded wall outlet and not plugged into a power strip.
2.
Make a color copy by pressing the Start Copy Color button on the control panel.
3.
If the error message persists, temporarily move the product to a different room or outlet, and then make a color copy by pressing the Start Copy Color button on the control panel.
4.
Check the part number on the power supply to make sure that it matches the part number listed in the User Guide.
Solution four: Perform a power cycle
1.
Turn the product off.
2.
Unplug the power cord from the product.
3.
Wait 30 seconds, and then reconnect the power cord to the product.
4.
Turn the product on.
5.
Solution five: Reset the product
Follow these steps to reset the product.
Step one: Perform a partial reset
1.
2.
Press and hold # and 3 while plugging in the power cord.
3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
If the partial reset resolves the issue, do not continue to the semi-full reset.
Step two: Perform a semi-full reset
CAUTION: Performing a semi-full reset deletes any phone numbers that are saved on the product.
1.
2.
Press and hold # and 6 while plugging in the power cord.
Solution six: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Mar 05, 2008 | HP OfficeJet d145 InkJet Printer
Hp 3380 scanner issue
I SUGGEST DELEATING SCANNER FROM YOUR SYSTEM AND RELOADING THE SCANNER DRIVER FROM THE INSTALL DISC THAT CAME WITH YOUR SCANNER
Feb 02, 2008 | HP LaserJet 3380 All-In-One Printer
24 people viewed this question
jasbo
jasbo
