Question about Yamaha RX-V630 Receiver
HELP!!1 Speaker Problem
Ok, this is weird. My surround sound will only play center with right side or center with left side or just the center. What the heck is going on!! Any advice?
  • 979 Answers
On all sources? Check all your RCA and line connections as well as the speaker connections. They must be firmly attached...accordianman
Posted on Oct 31, 2007
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
I have a Sony STR-DE605 and all of the right side channels are distorted and have to be turned up 1/4 before you can hear any ot the distortion but if i turn if off switch to the left sounds perfect.Center...
Sorry for a dump question ,
have you changed the distorted Right speakers to LEFT to verify if speaker is OK ?
First try with just STEREO ,not on Surround and please contact me for further solution possibility..
Take care..
Jun 27, 2011 | Sony STR-DE605 Receiver
In dolby digital mode i can not get any voice volume. All other sounds are ok
Assuming that you mean Dolby digital 5.1, confirm that you have a center channel properly connected and perform the following;
Using the remote, enter the menu on the receiver and navigate to the selection labeled "LEVEL." Toggle through the selections until you reach the "CENTER CHANNEL". You will be able to use the remote to increase the volume of that channel in .5dB increments.
Feb 01, 2011 | Denon AVR-589 Receiver
Lg lht854....wont play sound out of rear and center speakers
Try setting it first on surround mode because it is normal for the rear speakers not to come on when it is the surround mode is off. For the center speakers make sure it is hooked up properly. Follow the instruction if you have one. Lastly I never heard of center speakers have two speakers in it but if it does and you only have one set of wire to it then one of the speakers is no good.
Jun 26, 2010 | LG LHT854 Theater System
7.1 speaker setup: no sound coming from right front/surr speakers
Solution to having no sound coming from certain speakers in a 7.1 speaker setup for TX-SR606 receiver when playing a DVD.
Review the cable setup for the DVD player since it was identified as the source of the problem. Best to unplug and plug in the cables to ensure they contact the back of the receiver's RCA jacks. Redo the microphone setup for Audyssey 2EQ calibration. A good chance that it is the cable that may have caused the malfunction and loss of sound from the speakers. The cables can come loose during setup and not plugged all the way to the back of the RCA jacks or a defective cable causing signal loss.
Apr 15, 2009 | Onkyo TX-SR606 Receiver
Only plays one track from from DVD sound
Plug in center speaker -- seems right and left speakers are secondary carrying only the background / sound affects.
Jan 10, 2009 | Televison & Video
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
Yamaha RX-V630 Receiver Logo
74 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
