Question about Maytag Neptune MDG5500AW Gas Dryer
One of the paddles inside the dryer has come loose, how can I fix this?
Model mdg5500aww one of the paddles inside dryer has come loose. How can I fix this?
  • 149 Answers
Remove door screws and screws on opposite side. pull front forward and down. remove two brackets at top corners to raise top (unplug machine of course). screws are on outside of drum.
Posted on Jun 12, 2009
Inside part loose
if you are talking about the paddle, it is screwed to the tub from the outside in
Apr 01, 2014 | Crosley CEDC392JQ Electric Portable Dryer
Dryer banging sound inside while running
Check for a loose paddle inside the drum.
Dec 01, 2012 | Whirlpool WED4800XQ Dryer
I have a Maytag MD55 dryter and one of the paddles
You remove the door screws with the triangular plastic plates and screws for the door on the opposite side. pull front forward and down. Remove the two bolts at top corners to raise top (unplug machine of course). screws are on outside of drum. When reassembling, make sure that the right screws go with the right area (The wider screws go in the triangular plates and the thinner go in the door) Make sure the door hinges are put in their grooves before reinserting the front.
May 14, 2010 | Dryers
Paddle inside dryer came loose how do we tighten
You have to open up the dryer to expose the clothes drum. Most paddles are fastened by two or three 1/4" sheet metal screws. Look for your lost screw in the dryer or replace it with the same. Use a drop or two of lock-tite to keep screws in place. Good time also to clean out all lint which can become a fire hazard, replace the drum belt and redo all of the screws.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag mdg5500aww gas dryer sensor
First of all shut off the power by pulling out the plug.
If you are sure of the sensor issue then you need to remove four screws on the inside of the door. Two screws are located on the left and two on the right, look at the hinge and you will find two. The door will lift out when you remove the screws. When the screws are out of the front, the front panel can be remove by pulling on the outside surface.
Aug 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
GE Dryer (new) makes noise
few possibilities here,idle pulleys could be wearing,front drum guides could be wearing,back drum bearing,bit early for these problems though,but sometimes coins get lodged at the drum paddles inside located 120degrees apart which wouldnt be anything to worry about if you can verify this,hope this helps
May 12, 2009 | Whirlpool GEW9250 Electric Dryer
MDE7600AYW Atlantis Dryer -paddle inside dryer is coming loose
You will need to take the back panel off use a 1/4 in socket driver.Then you should see the drum.
Len
Feb 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer Paddle Loose
Take the four screws, out of the door and remove it. The front of the dryer will fold down and lift off, you will be able to see in side the dryer. If you want to lift the top remove the screws that are now exposed. Along with the brackets the top will now lift up.
This should allow you to access the tumbler.
Dec 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer model # mdg5500aww sensor not working is just starts a 37 minutes
How do I lift the top panel of my Maytag Neptune dryer model MDG5500AWW?
Jan 13, 2008 | Maytag Neptune MDG5500AW Gas Dryer
The paddle came off inside my Neptune Dryer
The screws for the paddle can be accessed by removing the small back panel. If they are stripped out you will need a new paddle.
Jun 07, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
395 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
