Question about HP Pavilion zd8000 Notebook
Nothing but wall paper hp pavilion zd 8000
Task manager is all that i can force to work. run a few things with it.
can't get f10 key to bring up hp recovery to set back to origional from factory software from recovery partition. instead it brings up ''Phoenix cME FIRSTbios pro setup utility.'' which is no help
to make matters worse he has broken his cd drive.
even though i can see a directory named ''start menu'' in command mode i can't get machine to find it and go into that directory.
  • 479 Answers
might be that the recovery partition is modifies so now recovery is possible through cd drive only.
Posted on Jun 02, 2009
How do i get the hotkeys to work on a HP zd 8000 laptop
If you have the remote for the HP Pavilion zd8000 you can use that to switch if the keyboard is faulty.
Feb 05, 2012 | HP Pavilion zd8000 Notebook
My hp Pavilion notebook computer's cursur is stuck in the middle of the screen and it won't budge. I have tried unplugging and removing the battery and turning back on and still nothing. The...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
May 27, 2011 | Computers & Internet
Hp zd 8000 boots in safe mode, but normally it gives me a blank screen. Hard drive error code #1-07error. Reformated and still the same issue.
you should run the chkdsk utility sit back and watch it recover the lost files it might take some time
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
hope this helps
Mar 28, 2011 | HP PAVILION ZD8000 SEREIS 100GB (4200...
Hp pavilion dv 8000 will not boot from DVD drive or Hardrive. It goes to LAN card regardless of precedent set in the BIOS
when u start ur system try pessing f8 or f10 or watever is the key for boot option nd from there u can select from which device to boot
Apr 05, 2010 | HP Pavilion dv8000 Notebook
I have an hp pavilion zd 8000 that does not boot
Hp has a really good on line chat to help with problems. What windows version XP,VIsta or other so on What part of the screen does it stay at. Not enough info. Can you what key options on side or bottom of screen to change to a bootup screen like F8. Tapping the key when the 1st screen appears till you get to a boot page . Then select last good configuration with your keyboard arrows the hit enter. This should reboot and see if it reconfigures to run.
Aug 31, 2009 | HP Pavilion zd8000 Notebook
OPENING THE CASE FOR HP PAVILLION ZD8000
Hi all
I have made another guide than the one that was removed from the net.
cleaning your hp zd 8000 in 9 easy steps... with photos and detailed a description.
how to clean a zd 8000 notebook
here is the link : http://www.realsancristobal.com/myguides/how_to_clean_a_hp_pavilion_zd_80.htm
hope it helps someone out there
Peace
Nov 10, 2008 | HP Pavilion zd8000 Notebook
No fan of three fans!
YOu can use software like CPUcool to monitor and manage your system. It uses temperature sensors (if available in your laptop) to measure temperatures, and has features to manage CPU speed and some more.
May 21, 2008 | HP Pavilion zd8000 Notebook
Hp pavilion zd 8000 dvd not working
you need drivers. to play DVD's I found a killer totally free player that does nothing but play movies. no sypware, spam or reminders to buy or limitations. http://www.videolan.org/ speaker are going to be audio drivers. right click my computer - properties - hardware - device manager, what ever needs drivers will have a yellow question mark
Oct 02, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
