Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
Problem for Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
My Bosch Dishwasher doesn't clean
By kidcarr_jr on Jun 02, 2009
However carefully I clean the filters, stack the contents, use high quality dishwasher tabs etc the machine leaves food debris all over the plates and inside the machine casing. Any stray rice grains or spinach causes particular problems. I can't work out how the food debris can actually pass through the filters and be pumped out. I am clearing the plates so thoroughly now that I might as well wash them by hand! I have never had this with other makes of dishwasher that I have had before. This was an expensive machine, it is only a few months old and I am thoroughly fed up with it. Like Chiggsy I clean the filter very carefully but food is often left on items; also, clean dry cups and glasses foam a bit when water is poured in as if a soapy film has been left. When I rinse carefully subsequent fillings are OK. Previous dishwashers have had a fine gauze filter fitted to the outside of the courser main filter. In my current model this fine gauze fits below the perforated "tray" in which the main filter fits and relies on compression (as the main filter is screwed down) to seal it top and bottom. as the main filter only screws down so far (bayonet fitting) I am not sure how well the fine one seals. Model is Exxcel (can't find more detailed reference) The top rack cleans fine....the bottom rack doesn't...As odd as it seems the left front bottom doesn't clean well..I don't see a blockage and the arm spins freely...HELP!!
Solution #1
posted on Jun 16, 2009
Not Helpful)
beckrisley
Rank: Apprentice
Rating: 40%, 1 votes
my dishes smell like wet dog? what could be the problem?
Was this helpful?
Yes
No
Solution #2
posted on Jun 03, 2009
Very Helpful)
localwonder
Rank: Guru  Bosch Dishwashers  Expert
Rating: 92%, 3261 votes
Check the following to address this issue--
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Jul 21, 2009
Not Rated)
GAZEBO 123
Rank: Guru  Bosch Expert
Rating: 90%, 55 votes
the fact that you only get the problem on the bottom basket shows the fault lies with the bottom spray arm first thing to do is put machine on with no dishes in it let it run for about 5 mins,then quickly pull door open,(it will stop) check to see which arm is still rotating it will probably be the top one, then line both arms up so they are at 12.0clock position shut the door and wait for a minute or two pull the door open agian and see if the bottom arm has moved from where you put it,if it hasnt it will almost certainly be blocked even a tiny bit of eggshell or rice will stop it turning,the very end holes are what drive the arm round even if all the others are clear it will not turn.
remove it and tap it and give it a shake you will hear debris inside of arm this needs to be washe out under hot water tap.
Was this helpful?
Yes
No
Popular Solutions for Bosch 24 in. SGS47E02 Exxcel
Questions and Unsolved Problems for Bosch 24 in. SGS47E02 Exxcel
Do you recommend Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher?
Answer
Answer
dishwasher doesn't clean properly, deposits left on dishes
Answer
my bosch dishwasher has never cleaned properly all the time we have had it. 2 yrs. It is now so bad... (More)
Answer
I have a Bosch LogiXX Auto option dishwasher. It was working fine for quite some time. But now... (More)
Answer
Bosch Exxcel auto option - Maxx Freedom Performance dishwasher - does not fill with water but runs... (More)
Answer
The dirty water is not discharging out of the machine. When I disconnect the drain pipe the water... (More)
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
