I see that others have replaced their battery doors...where can i get one from? My battery door has been busted for a while and I just decided to look into repairing it. Can anyone help me out? Thanks! do you have the details for kodak i.e a telephone number or email address, my camera is a kodak m893is and the battery door has broken.
Common Reasons Why Your Car Door Isn't Locking Properly The key fob battery is dead: This is one of the most common reasons why your car door lock is not working. If your locks aren't working, replacing the battery in the key fob could solve the issue. The key fob is faulty: If the battery isn't the problem, the issue may be with the fob itself. If you go to your car dealer, they can hook the fob up to a computer and make sure that the programming is still good. If it's not sending a signal, the fob will likely have to be replaced. A fuse is blown: If one door doesn't work, but others do, the problem could be a blown fuse. Replacing the fuse will correct the problem. This is a cheap and easy fix The solenoid is bad: Again, if one door doesn't work, but others do, the problem could be with the door lock solenoid. Replacing it may require removing the car door panel You have a broken wire: If the lock isn't getting power, hold the lock switch either up or down, and then open and close the door repeatedly to see if the lock will work. If it works sometimes, you probably have a broken wire
Door glass bursting usually occurs due to heavy impact while closing the door or if the car is left in over heated environment. Some time it may occurs due to high beat of music system also.
Replacement of the window by self is not more complicated. You need to remove the door trim panel and other electrical connection from the doors.
Then clean the busted debries from the door thru' a vacuum cleaner. Purchase the right spare glass from the market. Remove the glass rail fittings from the position & fix the glass in the guide rails, then refix all the rails in position.
Put back the electrical connections & door trim in it place.
Get a slim jim to unlock the doors, or bust the trunk key in and replace it later, or get another car just like yours and figure how to pop the hood from the outside, a lot of cars do it, but you have to know the secret. Hope this helps.
The door of a microwave oven tends to be considered a single sealed unit due to it being a safety-related item. Some can be dismantled and some can only be dismembered with a power drill. If the door is to be dismantled it requires much attention to detail in order for it to still be safe afterwards.
You will need a lot of luck to find a used handle but it might be possible to press other handles into service. Other than fitting a different sort of handle there is also some very good repair adhesives available today.
Many handles are manufactured from either hard plastic or diecast metal which when broken produce ideal surfaces for some repair adhesives.
Once the broken parts have been glued together it is best to glue reinforcement over the repair.
I repaired a broken windscreen wiper arm and fashioned reinforcement from strips of aluminium sheet and the result is strong and hardly looks out of place.
have that opened up in a service center and tell them that you dropped it. they will tell you that the sensor is busted. that will have to be replaced. hope this helps.
