Question about Hitachi 42HDT79 42 in. Plasma Television
PIP doesn't work
When I press the PIP button nothing happens.
  • jtclarke Oct 23, 2007
    I have a DVD and a HD Cable Box plug in and only the Cable box is turned on.
  • jtclarke Oct 24, 2007
    Thanks, I'll try that and let you know.
  • 55 Answers
Do you have 2 tuners hooked up or an additional source playing?
Posted on Oct 23, 2007
  • Michael Lugassy
    Michael Lugassy Oct 24, 2007
    Play something in the DVD and try toggling the AV-1/2 first to see both sources. if it works play with the PIP.
Lmd 9050 menu button doesn't work
you will need to remove the back cover to access the button panel board. then check for a loose connector, if ok check for an stuck up switch in the button panel.
Nov 15, 2012 | Sony LMD-9050 Monitor
Can't get pnp to work
I presume you mean PIP which is picture in picture---the only button which will control it is on the original remote--PIP, SWAP etc.
The set uses two tuners inside for this--one is main and other is PIP--you may have a bad tuner.
If PIP button brings up a screen--hit the swap to see what happens-if one is nothing or snow and other has a picture--got a bad tuner--it can be either (some are combined into a single tuner).
Jun 02, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
The PIP is on the screen and I can not figure out how to get it off.
When I had a Trinitron, I had to push the PIP button more than once to cycle it through all of the PIP options and then it would go away. Cancel or menu doesn't work...has to be pushing the PIP button. Hope this helps.
May 05, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
When click bb button my options buttom doesn work
If you are at the home screen and the phone is unlocked, press the "blackberry" key, next to the green answer button. The on screen menu should show "options". If you click on this, nothing happens? If it does pop up with the next window, the row adjustments are in the middle of this screen under "Set Homescreen Layout". Once you have selected this, be sure to press the blackberry button again and save your selection.
Hope this helps!
May 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Can not remove pip from sony 47"
hello just looked at the remote theres guide button next freeze press that should take you back to normal tv if that don't work get back to me
Jan 24, 2009 | Sony RM-Y908 Remote Control
32 xbr vega trinitron PIP wont turn off
Just press any channel number and PIP will disappears :)
Dec 25, 2007 | Sony KV-36XBR400 36" TV
Hitachi 42HDT79 42 in. Plasma Television Logo
76 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
