Question about Pentair IntelliFlo VS+SVRS Pump 230v - Provides Blockage Sensing w/ Auto Sh
Pentair pool pump vs 3050
Just purchased the vs 3050 pool pump, worked fine then it stoped turning on buy itself. Put in new 24 hr. intermatic timer. Turned on by itself for two days now it will not turn on. when the timer trips and I lift the cover on the pentair motor I see the gree light is on for power, and the green light is on above the number 3 button, but I must press the start button to turn on pump. can you help? william town
  • 64 Answers
These pumps should not be hooked into an intermatic mechanical timer. It should always have power supplied to it, meaning it should be installed to the line side of the power supply. Scheduling is done either in pump itself or thru an external controller such as a suntouch or easytouch controller, etc. When you have it wired into a timer like intermatic, power is interupted to the pump every day when the timer setting is for off. It is very hard on the drive of this pump, it does not like it, and will shorten the life of the drive. The pump was designed to always have power supplied to it, even when it is not scheduled to run. This may be the problem you are experiencing. HTH
Posted on May 22, 2010
How can I disable the pump clock on the intelliflo variable speed pump
check you tube for programming you have to put it into the controller mode or it will override it
Aug 11, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Key not in use
Yellow is the color to let you know that there is power to the pump, witch allows the pump to run according to your predefined start up settings. If you turn the power to the Pump off, the yellow light goes out, and after 72 hours, you will lose your pre determined startup settings.
Apr 19, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
My inteliflo VS 3050 it runs all the time Looks like the timer is not worki
There must be a relay inside that the mechanism activates that has shorted. I am not to familiar with the timer, but if the timing mechanism is completely mechanical then I would look at what this mechanism is activating.
Apr 07, 2013 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -leaks from housing
Which part of the housing?
The back against the motor or against the strainer basket housing?
Parts break down for the Pentair IntelliFlo VS-3050 here.
If leak is on the back of the housing - shaft seal. Or if the leak is on the front the replace O-Rings #10 or #23 in diagram.
Sep 13, 2012 | Pentair IntelliFlo VS-3050 & VS+SVRS...
I want to know how to program the pentair VS 3050. it runs nonstop even when the intermatic time box is in the off position. how can i reprogram it so it will run the way i want it to? we don't have...
The first thing I would do is read the owners manual. If you don't have one it is at the following address,
http://www.poolcenter.com/IntelliFloOm.pdf . I clean a pool that has the IntelliFlow and I control it manually. It works similar to the way yours does. Power is supplied to it all the time and according to Pentair the pump is supposed to be configured to the size of your pool, etc. I haven't read the manual but I am sure you can do figure it out after reading it. On the other hand if you paid someone to install and configure the pump then maybe you can ask them. I hope this helps.
Aug 25, 2011 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pump will work manually when you turn it on but will not come on all the time with a intermatic time clock. no power light on speed light, timer is in on position, reach down press desired speed and start,...
This pump cannot work with a mechanical timer alone.You would need to use a pentair controller to use this in the fashion that you desire. The intellicomm P/N: 520641 is the cheapest way to accomplish this feature. However, if you have the intelliflo vs-3050 WITH SVRS then you simply need to program the timer to come on and off when you want it to. If you have only the VS-3050 with no SVRS , then you need the intellicomm module. Just incase you have the vs-3050 with SVRS, I will post the link for the manual so that you know how to program the timer. Any other questions, im @ adamh@newconceptchem.com
http://www.pentairpool.com/pdfs/IntelliProVS+SVRSOM.pdf
Jan 10, 2011 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pentair IntelliFlo VS+SVRS Pump 230v - Provides Blockage Sensing w/ Auto Sh Logo
135 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
