Question about Jandy LXI 400 NATURAL GAS POOL HEATER -
Won't ignite Just installed the Jandy Lxi 400 natural gas pool heater. When I attempt to heat the spa or pool, the blower comes on, and it cycles three times in as many minutes, then the red LED flashes 3 times. There is a slight smell of gas when the igniter clicks, normal for my old one I replaced.
    Top Expert:
  • Jandy Master
  • 8,694 Answers
Make sure wiring is correct for 220 vs 110 wired for 220 from factory if 110 see inside panel move wires ignitor is not getting hot enough
Posted on Jan 30, 2016
5 Suggested Answers
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
  • 8404 Answers
SOURCE: Jandy Aqualink RS4 randomly turns on blower, pump, heater
Re program your assorted timer functions and make sure you set AM and PM or use a 24 hour clock. I think your model allows for a 24 hour clock setting but I am not certain.
I hope this helps you
a
  • 990 Answers
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Posted on Dec 12, 2009
  • 10 Answers
SOURCE: I have a Jandy Laars LX Pool/Spa Heater...when I
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Posted on Mar 07, 2010
Lcd readout not coming in
display screen should be getting 24 volts. make sure transformer is sending 24 volts from secondary side first
Nov 12, 2013 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Ignition locked
This means that the heater tried to fire 3 times without igniting. Cut the breaker to the heater to reset and try it again. Sometimes when a heater hasn't been fired in a while spiders will build webs in the burner orifices. Check the one below the ignitor.
Oct 27, 2013 | Jandy LXI 400 NATURAL GAS POOL HEATER -
The heater won't light up on my Jandy LXi400n Lxi heater
make sure red light is on for calling for heat if so make sure 24 volts ac on both sides of pressure switch if ok make sure gas is on
Jul 13, 2012 | Jandy LXI400N Lxi Pool & Spa Heater -...
Jandy lxi heater low pressure warning
check filters if ok check pressure switch and tube going to it
May 17, 2012 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Ignition fault LXI pool heater 400k
if ignitor is working try to adjust air damper make sure gas pressure is ok
Apr 12, 2012 | Jandy LXI 400 NATURAL GAS POOL HEATER -
New jandy LxI 400 natural gas pool heater makes a howlering sound which starts after it runs for about five minutes. The noise starts soft and continues to get louder. The noise is loud. Once I shut the...
Your bypass valve is bad. Probably because you did not pay attention to your water chemistry. It is located where the pipes enter the heater. You remove it from the side of the manifold that is outside the heater. It is not a difficult job. Just make sure your pump does not come on while the heater manifold is open!
Apr 16, 2011 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Jandy LXI 400 NATURAL GAS POOL HEATER - Logo
323 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
