Question about HP DESKJET 2200XI 14PPM 600DPI PRINTER p/n C2690A
Printer will not print
I have a dell computor with windowsxp. I installed an hp f2200 allin one. printer All connections are correct as per the installation disk. The cartridges seem to be ok as i have used the copier to print out two pictures.....colour and black. But no result when I write something as paper comes through blank I also has HP Deskjet F2200 series , I Install it without any problems and my computer recognize it .. but it out every thing as blank ..can you please help me ..
  • 11,896 Answers
I recommend downloading the latest driver updates. You can get them here:
h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972
Also check your printer settings to make sure they are set on plain paper and full size. Under your writing program, make sure your settings are unicode.
Posted on Jun 02, 2009
How do i override incompatible cartridge error message on my HP deskjet F2200
The ink cartridge is likely electrically damaged, to verify nozzle/electrical health run the 'Tap 41' diagnostic procedure:
http://www.youtube.com/watch?v=16uXSBwTan8
inkjet411 team
Mar 05, 2013 | HP Office Equipment & Supplies
Wirelessly connect to hp deskjet f380 printer
This model printer only has USB printer connection and it cannot be connected to a wireless network directly.
If you have a wireless router then you can connect a print server to this HP printer and then connect the print server to the wireless router. This will allow you to print wirelessly yo the HP printer when you configure the printer server and configure the printer driver in the computers to connect to the printer port IP address of the print server.
Jan 26, 2012 | IBM Computers & Internet
INSTALLARE CDA HP DESKJET F2200,L'ICONA SOLUTION CENTER
my hp f2200 deskjet printer solution center have not installed but are all are thing installed properly. my problem that i could not scan anything
Aug 12, 2009 | HP DeskJet F380 All-In-One Printer
Purchased f2280 some months ago, just setting up
click the link below to download the drivers for your f2280 from hp site directly.:
http://h10025.www1.hp.com/ewfrf/wc/product?product=3390947&lc=en&cc=nz&dlc=en〈=en&cc=nz
after downloading just install the drivers and connect the printer and its ready.
thanks.
Jul 08, 2009 | HP Office Equipment & Supplies
Cant connect (or see) my LaserJet 5000 on Windows XP
In XP go to START > CONTROL PANEL > NETWORK CONNECTIONS > LOCAL AREA CONNECTION
you should see a menu showing your network card and a window that says stuff like Client for Microsoft Windows. Below that window is an INSTALL button. Click on that and double click PROTOCOL. Select IPX/SPX NetBios and hit OK. You'll probably need the WindowsXP CD to finish installing the protocol.
The LJ5000 is a very old printer and if I remember correctly, it uses the IPX/SPX Netbios language to communicate through a network. Netbios is not installed by default in XP.
May 08, 2009 | HP LaserJet 5000 Printer
If this is connected via usb...then you should of run the cd before plugging the usb in.
Try unplugging usb and after a few seconds or so plug it right back in...XP should recognize/find new hardware and it will go a head and install automatically if cd had already been run.
If this doen't fix it you may have to go and remove it from "Device Manager" and do it all over from the beginning properly.
Feb 28, 2009 | HP DESKJET 2200XI 14PPM 600DPI PRINTER p/n...
Wireless Dell laptop can't 'find' HPDeskjet 5150 Printer
this printer is (as per HP specs) only connected via USB or Wlan Print server.
Check connection using USB cable and be sure Printer driver are correctly working.
Check on Router your Print server IP address (Lock it out of DHCP)
Put both PRT and PC on same home network (normally HOME or MSWORK)
Put Printer server IP address into your printer properties/port tab/ IP.
OR check if you see your printer server in your Windows network/home network
Jan 11, 2009 | Computers & Internet
Printer disc is f2200 but printer is deskjet f2280
Don't Worry you have the right disc.
The printer you have is of Deskjet F2200 Series and F2280 Is on of them.
Although the printers are segrigated but the Printer driver and software are the same for the F2200 Series.
So you can install the same.
Good Luck
Oct 04, 2008 | HP Office Equipment & Supplies
Dell Photo 964 - unsupported cartridge
How is it plugged first of all, did you set it up as a dell printer in add printer? try adding it as a HP printer since they are HP printers with the Dell name.
Oct 04, 2007 | Dell Photo 964 All-In-One InkJet Printer
199 people viewed this question
Seeker5211
Seeker5211
