Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Chemical smell from "outside" refrigerator.
This foul smelling odor is coming from the outside of my refrigerator. It is like a chemical smell. I have removed the drip pan and thoroughly cleaned it and replaced it. The smell is still there. This smell did not occur until I unplugged my refridg. to see why it wasn't cooling. I left it unplugged overnite and started it up again the next day. This is when the odor stared. I had an appliance repair man come out and he replaced the defrosting device that had actually broke in half. The fridg is running fine now, but I have the smell? Can anyone help?
Master_Tech
  • 770 Answers
SOURCE: chemical odor...
Is the unit working ok I think tech17 is trying to find out if you have a freon leak inside the unit??
Posted on Jan 27, 2008
bestdarngood
  • 3037 Answers
try putting crumpled newspaper in it daily to get rid of the smell, the coolant if leaking should not cause any horrible smell, Freon they use today has very little smell to it. Frost free units have heaters and fans in them to keep them frost free. It could be that a fan quit and the heater overheated something around it."
Let me know if this helps, good luck
Posted on Mar 29, 2008
22yooper
  • 828 Answers
SOURCE: Ice and Refrigerator and Freezer smell like alcohol chemical
All items stored in the refrigerator and freezer should be stored in sealed packaging. Frost free refrigerator operate with a very low humidity and will pick up odors from products. Somewhat of an ozone smell will be in some frozen foods. This is a normal condition. Deodorizing packs are available on the market to absorb odors. Baking soda does the job in most cases.
Posted on May 31, 2008
skeetermcgee
  • 7 Answers
SOURCE: i need help!
I had a problem similar to this as well, ungodly stench coming from under the fridge. I figured "must be the drip pan, easy to fix" totally wrong. I spend the better part of about 10 minutes trying to decide weather or not applying force to remove the from grill would break the damn thing or if it would actually come loose. After tugging like a maniac it did finally come loose. then i looked at the drip pan. It was taped down to the metal under cage. Cut the tape and Viola, came right now....NOT... I spend almost a full hour toying with this pan and the water filter and everything else and here is what i found.
To remove the pan you first need to unbolt the water filter holder and move the metal wire connecting it to the frame off to the side. (be very careful you do not pull the hoses out of the filter or apply too much pressure pulling and pull the hoses loose elsewhere) you then must unbolt the wheel that is in that same area as drip pan and water filter. Remove the wheel completely, (i stuck some magazines under the corner where the wheel was to come out of and it rested right on them.) now push the metal bracket holding the pan in place down until it no longer creates an obstacle and then bend the pan slightly as you pull it out. Don't bend the pan too much or it may crack but it actually slides out when pulled if "creased" in the center. It is a real ***** and there may be an easier way to handle this but this is my solution and the nasty pan in now nice and clean.
As far as spraying bleach in there goes i advise against it, the first thing i noticed when i got the pan out was that is said in big letters "CLEAN WITH WARM WATER ONLY." I though this may be more appropriate as a sticker in a place you can read it rather than on the pan you may not be able to get out :)
Posted on Oct 01, 2008
  • 93 Answers
SOURCE: Chemical odor in refrigerator/freezer
put coffeee grains or orange peeles this will take the smell away thanks from gilles
Posted on Mar 15, 2009
How do I eliminate a chemical odor caused by a cleaner?
several boxes of baking soda perhaps ..never use chemical cleaners in refrigerator soap and water only
Sep 24, 2015 | Refrigerators
Chemical odor in the refrigerator
The fridge working normally? Check the plastic around the bulb, do you see some coloring, if yes then the bulb in on all the time.
Mar 24, 2013 | Refrigerators
Hello i am having a foul smell coming from underneath the refrigerator. it doesn't have the drip pan on it..i removed it due to a previous foul smell..are these refrigerators known to have this type of...
the smell is bacteria caused by condensation from the drain pipe/drip pan,syringe with chlorine bleach, all fridges will smell if not looked after in the proper manner....but how many of us read the book......(if you removed the drip pan then you have the bacteria all over your floor.....will discolour/ruin any surface/carpet...
Jul 30, 2010 | Admiral Refrigerators
My refrigerator is one year old. There is a bad
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} You may have had something drip and somehow get under the fridge. I know blood dripping from meat will smell. It could have dripped down through the defrost drain tube to the pan underneath. You can access the pan from the rear by removing the cardboard cover. If the smell seems to be coming from the pan, it's difficult to remove so I would just pour some bleach in it to kill any smell and you may can wipe it out from there. The drain tube may also have the smell in it so you can pour some bleach into it from the inside of the freezer at the bottom of the rear panel. You can move the fridge to see if anything is pooled on the floor that might smell.
Jan 06, 2010 | Whirlpool Refrigerators
Kenmore side-by-side has CHEMICAL SMELL ODOR inside.
You have a freon leak. With this only being 5 years old, iot's probably worth repairing, unless you are just able to buy a new one. I would have a local tech come out and check it before tossing it. I hope this answers your question and gives you some resolution. I hope to work with you again, so please record our name, email and phone number for future needs. Have a great evening!
Sep 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Foul odor from beneath the frige!
You have a couple possibilities. Either something spilled in the frig and ran down into the drip pan or you have a dead critter under there. The pan is not removable and cleaning it is a pain. take a good look under there from the back and the front.
Eric
Jun 24, 2009 | Refrigerators
Smell fish odor when fan comes on.
Tim, Clean the refrigerator completely with clorox and water. Unplug and remove the rear panel in the back of refrigerator and wash the evaporator coil with this solution. Check the amount of flow to the condensate pan below. The drain line has the gel and this contaminated smell from top to bottom and you will need to insure that all the smell remaining in the drain is draining freely and decontaminated with the clorox. Do these things and wash the remaining pan below the best you can and you will be set to go.
Jun 20, 2009 | Whirlpool GD2SHGX Refrigerator
There is a sour smell that comes out of the bottom front of my fridge. It is a side by side Frigidaire with an ice maker. It does not smell inside, only the exhaust air and it smells up my kitchen. I have...
There is drip tray underneath the unit. Depending on model, there are multiple ways to access. This tray needs cleaning regularly. Once clean, sprinkle in Baking Soda to keep odors down. Cleeaning this on a regular basis is the only way to beat this smell.
May 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
292 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
