Question about Zerus Intel Desktop Board D815EEA (Z-D815EEA) Motherboard
ASUS M3N-HD - CASE (w/ PS): Foxconn- TSAA-725 . The problem is that the case has a Power led connector which doesn't fit with the module on the board. It like CASE: 10, MB: 1-0. "-" stays for a space between them. Any solution?
    Problem Solver:
  • 13 Answers
So, the M/B has a 3 pin connector, but your case only has a 2 pin connector? Easiest way is just to cut the connector from the case in half with a pair of sissors.. It isn't the most nice solution, but it works quite well!
Posted on Jun 02, 2009
Changed the pc case and i can't find power led and hdd led, can you please help me with the labelled motherboard?ASUS P5GD2-TMX/S
Power and HDD LED's are on the front of the computer case. The connectors for them are there and they can only plug in to one place usually if not the board is labeled as you say . You can't hurt it so try plugging them in where they fit.
Apr 01, 2011 | ASUS Computers & Internet
Sound cable connection
Look more closely at your motherboard, for a 4-pin "PC Speaker" label.
The "HD Audio" is _OUTPUT_ (left front, sub-woofer, right front, left back, right back) to Surround Sound speakers.
Dec 31, 2009 | Foxconn (945G7MA-8KS2) Motherboard
I have just gotten a new PC case, but can't find the pwr conn.
The front panel connector is close to the SATA connectors. If you look real close (as in flashlight and magnifying glass) at the printing on the motherboard, you will see "pwr_led", "pwrsw", "hdd led", and "reset" printed on the board. Just match what it says on the wires to what it says on the board. Polarity only matters with the LED's. If they don't work, just swap the leads.
Here is the manual for that mobo:
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001142
Dec 31, 2009 | Computers & Internet
Dear Sir/Madam, I have a motherboard of a Fujitsu Siemens D1520 (Foxconn) with name: w26361-w51-z1-04. The connections of the Frontal Panel (power LED, IDE LED, reset switch and power switch) consist of...
On the Foxconn boards all connectors are the standard model, always with the name of the connector printed on the board. In your case probably the speaker has a wide connector - 3 pins wide instead of 2.  Just pair the matching names.
Here are some generic instruction - http://www.pcguide.com/byop/byop_OtherCaseConnectorsandSwitches.htm
Sep 13, 2009 | Foxconn Computers & Internet
Need to know where to hook up the card reader and 2nd HD. I have an ASUS M2N68-AM motherboard and I was looking for a schematic for this board to tell me where I can safely hook things up.
I assume you have an external card reader with a USB connector. If that's the case, you plug the device into an existing and available USB port, either on the front or back of your PC, or side or back of your notebook.
If it's an internal one, then you should find an available power connector from the power supply, and you will probably need to remove a plate in your PC case to install the device.
Regarding the second HD, any connector on the motherboard will usually only accept its own matching connector from the new device.
If your HD is SATA, then you probably need a second data cable, since the power supply comes with two SATA power cables.
It should be connected next to the existing and identical connector for your existing HD, assuming it's also SATA. It the latter it's an IDE type HD, then you should try to find a matching set of connectors (usually two), and attach the data cable to either one. It does not matter which one you choose in this case, since your PC is already booting from the IDE HD and will consider the second HD as additional storage, not as your boot drive.
Aug 16, 2009 | ASUS M2N68-AM SE2 Motherboard
Aftermarket case trying to figure out the wiring not full plugs and don't know where on motherboard they fit anyone have my solution it's a hp board ms6577ver 4.1
if the motherboard is atx and the power supply is atx then the mb connectors should be marked on the mb and power supply. the mb side you will need a magnifier to read the small print. they will be in a line together somewhere near the lower corner of the board, in a straight line. usually rst is reset - hdd led is hard drive led and the square 20 pin conn, goes somewhere near the processor. if you have at board or powersupply it won't work they both have to be the same form factor. there are others and not knowing the case or ps i cant give you more info.
Jun 15, 2009 | Microsoft Windows XP Home Edition
FITTING MOTHERBOARD
If you have not removed the old motherboard from the case, then you can identify the various front panel connectors as you disconnect them and label them. Some front panel connectors have labels printed on the connectors which makes it easy for you to identify its purpose. If you have already removed the old motherboard then you will need to trace each of the leads to the front panel to see what they are connected to (eg. the LEDs and switches etc).
You will also need to identify on the new motherboard the various connectors for each function, eg power LED, hard drive LED, reset switch, power on switch, internal speaker etc. If you are lucky It may be printed on the motherboard, if not you will need to refer to the manual.
NOTE the LEDs are polarity sensitive, if the LED does not light, then swap the connector around the other way.
Nov 16, 2008 | Packard Bell Computers & Internet
Can't locate hd led on the board
Click the link below & download your manual. You'll have to fill in the three windows to get to your board.
Motherboard
Socket478
P4VP-MX Click search. Than open the + sign for manual.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Go to Pg.1-22 section
11. System panel connector (10-1 pin Panel 1)
See the diagram at the top of the page.
You might need a flashlight if the board is in the case!
please vote...
Feb 22, 2008 | ASUS P4VP-MX Motherboard
Foxconn motherboard red light and nothing else
Remove all connectors and cards except vga and power supply. and one stick of memory and start there.
If its still an issue remove the board from the case , it may be shorting out on something and try it outside the case,
check the power supply switch for 110/220v switch on back if it has it.
to manually trigger the power supply on the 24 pin connector
short the green and black wire that is next to it.
Jan 26, 2008 | NEC Galileo 845GL (N4-IBFGL) Motherboard
Asus P4GE-MX
If you have your manual you can see how to connect these on pg. 1-22. No manual..
Starting from the right edge of the board moving to your left. Notice there is two rows of pins one above the other. All your case connectors will be connected left to right & not up to down. The first two (BOTTOM ROW) pins are for the reset switch. The connector will have two wires one will be colored white or black. These colored wires are ground & will be the sane for all your connectors. All grounds will face towards the right for both rows of motherboard pins. After plugging in the reset connector SKIP one pin as you move to your left along the bottom row. Plug in your IDE LED connector a two wire connector. Moving to the top row across from the ide led, plug in the Power Led. It is a two wire connector. Some case connectors for the power led come in a three pin connector. If yours is like that than you will need to remove the + wire from the connector & slide it over one slot so it is next to the ground & plug it onto the board.
The last two pins is for the Power button. All Asus boards are marked & colored. You need a stronge flash light to see the markings on the board. Good luck!
Don't forget to vote..........
Jan 15, 2008 | ASUS P4GE-MX Motherboard
Zerus Intel Desktop Board D815EEA (Z-D815EEA) Motherboard Logo
235 people viewed this question
Top Zerus Computers & Internet Experts
David Payne
David Payne
Are you a Zerus Computer and Internet Expert? Answer questions, earn points and help others
