Question about Dell Inspiron 6400 Notebook
Dell inspiron 6400 problem in switching on
Hey
My dell inspiron 6400 is not getting switched. When I push the power button, the led on the left panel blinks for a second and after only the led on the right panel glows. The screen is completely blank. I was able to run the diagnostic check by pressing the Function key and power button, and it was not showing any error in any of the hardware. I observed this problem two days before and then it got corrected automatically. Now again it has started. can anybody help me with suggestions
Thanks
  • 2 more comments
  • haridas_otp Jun 02, 2009
    Thanks for reply....
    yes I could see the DELL logo before diagnostic checks were started.
    For normal starting there is no display at all. I could feel some
    vibrations just next to the touch pad for two three seconds while
    pressing the power button and after that nothing.... There is no bios
    beep sound also.
  • sweetyanne
    sweetyanne May 11, 2010
    were you able to see the dell logo? if the hardware diagnostics says that there is no problem, then we can try to check the os,if ever you will see the dell logo,tell me.
  • Hank May 11, 2010
    When you press the power on button do you hear any fans running, or hard drives spinning? Do you hear any bios beeps?
  • Gyanendra Kumar May 11, 2010
    hi,
    did you try recovery ?
  • 68 Answers
Hi there so once you see the dell logo keep on tapping f8 and check if you can enter the safe mode, if not tell me the lights because that means thats its a no post issue and we might need to reseat your memory.
Posted on Jun 02, 2009
3 lights o right hand side of laptop what do they mean
The user manual will supply an in-depth explanation of the led-indicators, aswell as there are normally small icons assigned to each light, sometimes engraved in the plastics, normal lights to be active at average usage are the Power led indicator, will glow as long as device is turned on, the Wireless led indicator will glow when the wireless network module is active, the CPU led indicator will flash occasionally when system is idle, and rapidly when system is active under load, and the Battery led indicator will be active when device is running on battery power. When device goes into sleep or hibernate mode the sleep led indicator might continuously glow or slowly switch on & off varying between systems.
May 27, 2010 | Dell Inspiron 6400 Notebook
Power jack replacement Dell Inspiron 6400
When you press the power button, no lights, fans, beeps, anything?
Is the power jack moving around? If not, I would check the charger and cord to make sure power is getting through to the plug that goes into the jack.
Jan 14, 2010 | Dell Inspiron 6400 Notebook
Inspiron 6400 is not getting started
Adapter should be faulty,kindly check with one another.
if again you are facing the problem might be short circuits in the motherboard
regards,
pp
Nov 26, 2009 | Dell INSPIRON 5000E (969PG) Motherboard
DELL inspiron 6400 not switched on
This is a no boot issue. Youre saying that you can perfectly run the PSA diagnostics but doesnt load Windows rather it stays on black screen, meaning the boot loader of Windows failed to load. You need to reinstall windows on your computer
Jun 02, 2009 | Dell Inspiron 6400 Notebook
How toturn on wireless in dell inspiron 6400
you should have a key on keyboard in lower left corner by windows key that says"FN" then hit "F2" that should do it, if that is not the case then there should be a switch along the edge of machine
May 01, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 cant get wireless connection
The Wi-FI light turns on when wireless networking is enabled. To enable or disable wireless networking, press and hold the blue <Fn> key and press the <F2> key. The <Fn> key is located on the lower left hand side of the keyboard.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 19, 2009 | Dell Inspiron 6400 Notebook
Switching on the laptop
Try holding the power button down for about 10 seconds. Then try turning it on.
Next remove the battery and try to start with just mains power.
Next replace the battery in the computer and let it charge.
If this does not work you will probably have to contact Dell
Nov 15, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Power Problems
Sounds like the power pin is either loose or damaged. . . .Happens from jerking or tugging on the cord too much.
Once you get it fixed you need one of these. . .
Sep 08, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
266 people viewed this question
Alun Cox
