Question about Western Digital Passport® WDXMS1600 160 GB USB 2.0 Hard Drive
My WD250 MyPassport external HDD powers on and makes the booting sound all right. It lights up but windows XP never detects it. It used to work prefectly okay before. Any advice.
My 250 MyPassport powers on and makes the booting sound all right. It lights up but windows XP never detects it. It used to work prefectly okay before. Any advice. Thanks
  • wazab Jun 02, 2009
    Thanks Chris. I am talking about the 2.5, the small palm size one like the one in the post picture.
    I already did the USB calble test and none of the three I tested worked. I get the same result, boots up, lights the blue button and thats it. I tried the HDD on other PCs and I got the same result. I am now trying my luck with the people at the shop. I'll get back with any updates. I appreciate your help. If you have any additional usful steps to follow please send it to me.
    thanks
  • wazab Jun 07, 2009
    Ok chris, I'll give it a try.
    thanks
  • 696 Answers
As you did not specify 2.5" or 3.5" I will give you both sets of steps:
If it is a full sized hard drive and requires power, it may not be getting enough power, have the AC adapter tested at a computer shop. If it is dead/dying replace it, if not move onto the next step.
Try a new usb cable, also available at most computer shops. If the new cable works at the shop try your old cable as well. If the old one doesn't work, buy the new cable, problem solved if it does work the problem is either in the caddy or your computer.
Assuming it's in the caddy, now have the people at the shop swap the HDD from your shell into a new one and test the drive again, as with the above if it works you're done. If it doesn't the problem is internal to the actual HDD. Time to buy a new external drive and send the old one for recovery if it has any crucial data on it.
Let me know how you make out and if needed I will provide additional steps. Also if you need data recovery help let me know your region and city and I will recommend an appropriate facility.
Chris
Posted on Jun 02, 2009
  • Chris
    Chris Jun 02, 2009
    Thanks for the clarification, a lot of people post under the wrong items so I like to verify.
    Sounds like you've worked through a few of the usual steps. Let me know how you make out with a new enclosure. If it fails to give results let me know along with your region and I'll get you in touch with the pro's.
    If it does work, just let me know and please don't forget to rate the solution.
    Chris
Toshiba 500 GB External Hard drive cant be detected by windows xp
yes you could simply format the harddrive in Fat32 using your macos that would be the best solution but don`t forget to backup your data by copy pasting the files on your mac or something else and after that to move them on the external hdd again to be available on the windows machine
Mar 11, 2010 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
CPU won't read it im running xp
Ok, here's some step by step instructions.
First is the light on the nexstar coming on when you plug it in, if so what colour? If not try using both USB connectors on the PC end to plug in, it's possible you're not getting enough power if the light is not on as many 2.5" hdd enclosures require 2 USB connections one for power and data and the other for additional power.
Next, if the light is on but no drive in my computer, right-click on my computer, then left-click manage, select disk management from the MCC window that pops up. If your Nexstar HDD shows up here, identify it on the bottom part of the window and report back what is said there.
If it is not there and the light is on, try a different USB port. If the light is not on or you tried the other ports and still no luck the enclosure itself may have failed.
Try moving the HDD into a new enclosure and try again. If this works, Great, if not then the HDD may be damaged and may need a pro to get your files back. If that is the case report back here with your progress and region and I will recommend an appropriate pro.
Hope this helps FixYa,
Chris
May 09, 2009 | Vantec NST-285S2-BK NexStar SX 2.5"...
Ihave purchased a SeagateFreeagent 500 gb USB external HDD.It was working very well till I tried to create partitions by using Paragan Disk Management software. In the middle of formatting the partition...
After plugging ur HDD, verify the device is detected or not in Device manager and Try Partitioning Again GUI mode (means in XP).. or follow the steps..
1- Go to Computer Management, Click Disk Management
2 - You will find you External HDD in the Right side
3 - Just Right Click the Drive, if it asks Initialize HDD, just Initialize and Create Partition as u like.
Have Fun
- Rajkumar
Mar 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
HDD needs urgent recovery
If the drive is corrupted the data is useless.
May 05, 2017 | Computers & Internet
Make a pen bootable
I have got a solution this day for an other member.
Fist select in the BIOS SETUP the BOOT SEQUENCE and place in the firt place the USB drive to the secon your HDD ou CD-ROOM drive ans so one.
Be sure you have format your USB device as SYSTEM and have the system on it. Thats all.
You can download a light version of WINDOWS XP and put it on the USB flash drive or external USB disk.
Dec 12, 2008 | Computers & Internet
External USB drive making clicking noise - Windows does not recognize it!
The drive is damadged bad. youll have to go to a data recovery centre, but that can cost $700+ if you really want your data back.
Sep 19, 2008 | Western Digital (WD1000VE) 100 GB Hard...
it is going to crash soon as the platter seems to broken it is non repairable yes but u can save the data by taking help of any good tech
May 19, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Virous in removeble harddisk
try to boot to safe mode, and see if it is detected. If it is detected in safe mode. Uninstall and reinstall any drivers that came with your external hdd. If still no go, reinstall windows. If after reinstalling windows, still not detected, replace external hdd.
Feb 16, 2008 | Microsoft Windows XP Home Edition
External HDD won't start up
putt the actual hdd in master and the 1 ur having problem with in slave mode boot windows go 2 controle panel administartive tools and device manager or manegment somthink like that and in the diagnostik box take the last option frome the second 1.u must see ur seond hdd that u put on slave..format it...after that putt it alone and boot frome windows xp and install ur windows this will work
Jan 08, 2008 | Computers & Internet
Western Digital Passport® WDXMS1600 160 GB USB 2.0 Hard Drive Logo
116 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
