Question about Welding Tools
Tig 250/250 I tried to used the tig but it seems like there's no gas, chcek all the lines but there's no leaks. Machine was set at DC-, and Med Doing Mild Steel welding Any help would be nice Thanks, Lee Email me at 2slick2kick@gmail.com
  • 3 Answers
Have you checked your regulator if its gone you wont get gas
Posted on Jun 02, 2009
What is TIG and MIG wielding?
Both are different wielding methods used in metal fabrication service. Tungsten inert gas wielding or TIG is high quality arc wielding and is used for high quality wielding applications. Metal inert gas or MIG is another form of wielding.
Jun 10, 2013 | Welding Tools
Can't set up syncrowave 351 to tig weld aluminum. I can not seem to get the settings right to melt the aluminum. It just leaves a bif spot on the aluminum plate.The plate is about 1/4" thick and...
Set the "arc balance" control between 40-50, also. You need to be up around 200-220 amps too. Make sure you're using 3/32 tungsten (green, red) and running about 25-30 cfh on your argon. Ball that end on the tungsten.
Oct 08, 2011 | Miller Electric Manufacturing Electric...
Lincoln precision tig 225. Makes bad aluminum welds in AC. Welds show signs of contamination. Have tried new argon bottle. No leaks in gas lines. Using pure and 2% thoriated tungsten, 3/32, pure...
Hello; Make sure AC Auto Balancing is Enabled; And when Welding Aluminum Aways use 100% Pure Green Coded Tugsten.Make Sure you dont have 75/25 or possibly if you know for sure your frequency balancing on your machine is working you could possibly have a bad bottle of gas try the bottle of gas on the machine that you say that runs good if it runs good put it back on the 225 if the problems still exist there is something wrong with your machine`s Ac high freqency Auto Balancing.Make sure all connections are good,check tig head for loose connections. Step Up to A 1/8 size tugsten it will carry more heat and gets less contanimated.Every time you stick your tugsten it will run contanimated untill you burn it off or clean it ,if you stick you tugsten go ahead and put a clean piece back in the tig head, Contanimated tugsten wil run dirty for 5 to 20 minutes Untill you BURN it Back Clean !?
Sep 03, 2011 | Lincoln Precision Tig 225 Ready Pak With...
Syncrowave 250 dx aluminum set up
You can go to millerwelds.com and download the manual for this machine..it should help you
Dec 13, 2009 | Miller Electric Manufacturing Electric...
Miller Syncrowave 250 / no tig arc start
seems that you have a ground issue. make sure the ground clap is on barte metela and secured tight. make sure your tungsten electrod is about 1/8 of an inch form the edge of the cone. you will find that you will get a faster arc this way.
Apr 10, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Tig my pudle melts into gray not shinny
Ensure you have the correct angle when using the torch = 22-24 degrees from vert: this will provide good gas coverage. setting should be 15 - 20 ltrs using a "flow meter".clean the material thoroghly then weld , dont clean then leave for a long time.
Argon gas sometimes can be contaminated and cause heavy soot on the weld bead,
TIG electrode should be Zirconiated with a rounded end not pointed.
Use forehand ,method
Feb 02, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
TIG welder help
Choose the electrode to use for the project you are starting as well as the variety of alloys you'll use such as the 6061 Aluminum alloy electrode. Grind the electrode to a point. Try to create a tip and sharpen it to help it become more rounded as you weld. Place the electrode into an electrode holder with the tip about 1/4-inch away from the sheath. Choose the settings on your tig welder. The three main ones are AC, DCEP and DCEN. Choose AC for aluminum. Slide the "cleaning/penetrating" slider more to the penetrating side. Set the "air on" to five seconds and the "max amps" to 250. Turn on the gas. For aluminum, use pure argon. For steel, an argon and carbon dioxide mix. Scrub your welding table or flat piece of sheet metal with a wire brush to make it clean and flat. Gear up in full welding safety gear including hood, goggles, apron and gloves. Hold the electrode in your dominant hand and start your welding project. Check your settings every so often to make sure they haven't changed and adjust as needed.
Aug 27, 2008 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Welding Tools Logo
184 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
