Question about Sony PlayStation® 3 (60 GB) Console
Ps3 will not turn on
I was traveling with my ps3 on vacation and it was working fine while I was on it. When I got back, I tried to turn it on it goes green for a few seconds then yellow then beeps 3 times and flashes red. I've used a vacuum to see if caught any fibers from the blanket I wrapped it up in so it wouldn't get damaged. I tried again but no luck. I even used an aerosol can to see if it could get rid some fibers the vacuum couldn't. I'm stuck please help!! I have data I can't afford to lose on it. seme problem wont turn on and it will blink a bunch of times then turn off
  • 4 Answers
Pull the hard drive out and put it in another ps3, if it works then its a hardware failure if it dont then its ure hard drive or ure firmware. if u move the ps3 to much it will mess with the hard drive
Posted on Jun 02, 2009
The digital panel spontaneouly beeps inidcating temps which is a normal to cross check,
Vacation mode is a setting to limit defrost function during long periods of disuse, the manual can tell you how to exit vacation mode. If the unit goes into vacation mode without being prompted to, then replace the main control board...
Apr 23, 2016 | Refrigerators
Went on vacation and left the PS3 powercord unplugged. Now it doesn't work, could it be the cable?
Hey there, a couple of things to verify here to get your ps3 back up and running. Do not worry about leaving your ps3 the whole week with the powercord unplugged, this is OK and should't have affected anything negatively.
1) Make sure that the powercord is well plugged on both ends: ps3 AND in the wall.
2) Make sure that the SWITCH is turned on (in the back of the ps3, there is also a POWER switch I/O). Turn it on by pushing on the I.
3) If it's still unpowered, try plugging the ps3 itself somewhere else in the house (to make sure it's not the power outlet)
Jun 23, 2011 | Sony Playstation 3 (PS3) Console
When I turn on my PS3, the sony music begins and the orange sony wave screen turns on but it doesn't move on to the menu. I have shut the system af by turning off the button at the back of the PS3, I have...
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
ok don't install the hard drive in any other unit or you will lose all of your data the problem you have is similar to the xbox 360 red ring of dead yes this is right yous ps3 is dead but some units can be fix with special tools to remove the VGA and fix any broken connections under the VGA YOU KNOW THEY ARE TINYCONNECTIONS this is why you need an special tools for it
last week I fix 8 units out of 10 2 where not fixiable and is not spenced I only charge 65.00 dls if I can fix it if not htere is no charge all what you have to do is ship the unit or only the mother board if you can opened and pay for an return label so I can return the unit back to you
and don't worry I am a thusted ebay power seller you can pay me using your paypal account so let me know if you will like to try riverajuan@univision.com OR EBAY user Id flacooo1
May 29, 2009 | Sony PlayStation® 3 (60 GB) Console
PS3 does not work in 1080p
My ps3 didn't like a HDMI connection very much. I tried the Composite input cables and they worked great with no screen flicker.
-Captain Jake
Feb 13, 2009 | Sony Playstation 3 (PS3) Console
PS3 will not display on TV
WHEN YOU START YOUR PS 3, KEEP YOUR FINGER ON THE START BUTTON UNTIL YOU EAR A SECOND BEEP ( BETWEEN 5 & 10 SECONDS); THIS WILL RESET AND SELECT THE RIGHT CONNECTION . I HAD TO FIND THIS PROBLEM WHEN WE WERE SWITCHING FROM THE LIVING ROOM TO MY KID'S ROOM.
LET ME KNOW, HAPPY NEW YEAR.
PIERRE ( MONTREAL)
Jan 01, 2009 | Sony Playstation 3 (PS3) Console
My PS3 is stuck in set up mode and I can't exit to play Rockband?
shut PS3 off with the back of PS3 switch then turn it back on.
Dec 24, 2008 | Sony Playstation 3 (PS3) Console
Ps3 power
Try and find a better/different adapter, maybe one the is specific for the PS3 or gaming in general. Don't use one of those universal ones, could fry your PS3.
Not sure what kind of outlet/plugs you guys have out there (I'm in Canada, eh) but I've provided a couple of links that should help you out. Personally, NYKO is a great choice, quality stuff and they have lots of accessories for the PS3.
http://discoazul.co.uk/powercord-nyko-ps3-european-plug-adapter/product_info.php/products_id/3206
Due to the volt difference; Europe (220v) vs. Canada & US (110v)
you MIGHT also need a power converter. Check the console, it will probably be able to handle 110v-220v but double check to be sure. I have heard all kinds of answers and opinions about it but best to check your PS3 yourself. If it odesn't support both voltages then you will also need to get a power converter.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Picture won't show up.
well make sure that the av cable is in tight in the back of the console and if it is wiggle to see if u can get a picture or somthin
Aug 03, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
