Question about Epson LQ 680 Matrix Printer
EKM!1395/5 AEKM!!!!! printing message
I am trying to print with my Epson LQ 680 printer but instead of printing my document, it prints out this only readable message - EKM!1395/5 AEKM!!!!! - then followed by garbage printer output, then it will halt with a beep, then again prints garbage, then beep, and so on. I also tried to print the test page but similar thing happens.
    President:
  • 1,185 Answers
Unistall the printer using the Control Panel
Go to Epsom www.epson.co.uk/
Obtain the drivers for the printer and copy them to a location on your hard drive re-install the printer using the Add Printer in the Printers and Faxes area if XP finds the LX allow it to install.
Once it is installed do a Print Test page , if the print is correct you are on a roll if not go to Device Manager and ask it to update the driver
It will ask you if you have a better driver say yes and point it to the entry you made on your hard drive
Posted on Jun 02, 2009
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
When I print tables, the lines come out crooked. Any idea what the problem could be?
do the print head alignment... to do this..first switch OFF the printer and then load paper, press the Pause button while switching ON the printer.. the printer will then print the instruction for you to align the print head. Just follow the instruction and select the best printed line.
If when you print text or line, and you notice there is some part missing, this show that you print head have broken pins. If this happen, you will have to replace the print head.
Jun 14, 2010 | Epson LQ 680 Matrix Printer
Today I cannot print to epson lq 680 and cannot detect printer
turn off the printer remove the cable into computer. turn on the printer again. maybe the cable it cause of the problem
Feb 09, 2010 | Epson LQ-680 Matrix Printer
The printer does not complete printing the page and starts printing the other page whereby the first page is half blank.please assist me
good day. you may try re installing your printer driver and follow the steps carefully, hope this helps, have a nice day
Feb 04, 2010 | Epson LQ 680 Matrix Printer
The contents no in the right place
check the ink. check to see to the file fits the paper in print preview mode. if you still have problems take it to best buy.
Feb 10, 2009 | Epson LQ 680 Matrix Printer
Speed of print
A printer is designed to print at a certain ppm (page per minute), so really there is only one way to speed it up. When you select the print option from the File menu, you can select properties and see if you can change the dpi (dots per inch) of the document. Your document will print faster but you will lose quality.
Nov 27, 2008 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-680 Dotmatrix
Sounds very much like you using a incorrect printer driver not the driver for LQ Dotmatrix. Uninstall and reinstall make sure you using correct LQ series driver and this is your default printer.
Sep 09, 2008 | Epson LQ 680 Matrix Printer
Cross printing
I'm not sure exactly what your issue is, but Epson printers should be well supported as far as drivers are concerned. Do you have the correct driver loaded? If you are trying to use a Tally driver with the Epson printer, this may not work right.
Also, when printing from Windows, some older printers print only in a single direction, from left to right, instead of bi-directional (left to right & right to left).
I've used a few different Epson dot matrix printers, and problems have been few.
Feb 26, 2008 | Epson LQ-1050 Matrix Printer
Printing
I can not print with Epson printer Lq-2180 , wheras I install driver into windows2000 And add printer, when i send command print ,the printer do not reflex.
Oct 31, 2007 | Epson LQ-2180 Matrix Printer
Epson LQ 680 Matrix Printer Logo
1,304 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
