Question about Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 washing machine stalling mid-cycle
My bosch washing machine, 14 months old, stalls in the cycle. The clock shows one minute to go, but the programme gets stuck on wash and never proceeds to drain or spin... any ideas? Thanks! Hi, I have same problem with Bosh Classic ixx1200 express, the clock showing 1 minute to go but machine washing, washing, washing
    President:
  • Bosch Master
  • 662 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
Posted on Jun 17, 2010
My bosch classixx 1200 washing machine wont pass first cycle, it will take in water and the drum will turn and keep turning thats all it will do whats wrong. please help
THE PROGRAM IS FIXED IT WORKS LIKE A CLOCK TRY TO OPEN AND SEE IF THE PROGRAM IS WORKING YOULL HEAR AS A SMALL RUBNNING CLOCK PUT SOME LIGHT MACHINES OIL TO HELP ITS MOVEMENT IF NOT CHANGER THE PROGRAM
Oct 21, 2014 | Bosch Washing Machines
Does the Bosch Exxcel 7 1200 Express have a child lock function?
try the manufactures website for free manual download
Dec 08, 2013 | Bosch Washing Machines
F-16 message showing on my bosch 1200 classixx
Usually means the door is open when the start is pressed, so either you have not closed the door before trying to start the cycle or there is a problem with the door lock
Nov 07, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Oct 12, 2009 | Bosch Washing Machines
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch classixx6 1200 express
my classixx6 1200 express is flashing f21? what is wrong with it?
May 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
1,431 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
