Hello, I haven't used my scanner for a very long time. Now i plug it in to my xp system. It doesn't respond at all. Is there a power switch button? or any other switches? Thanks a lot.
My SVP FS-1000 does not scan with the color or clarity of the original color slide. Yellows are...
(More)
My SVP FS-1000 does not scan with the color or clarity of the original color slide. Yellows are washed out. Backgrounds are frequently green or blue when the original was white or gray. Individual color adjustment is tedious and frequently not right in that to get the background close the reds are too dull. What can I do?
scanner fell off the top of the pc system unit onto the carpeted floor - maybe 15 inches. now wont...
(More)
scanner fell off the top of the pc system unit onto the carpeted floor - maybe 15 inches. now wont work. can't believe such a small fall will have permanently wrecked it. what next? message is " cannot co0mmunicate with scanner. cable may be disconnected (which it isn't) :check stauts: scanner driver will be closed ; code 2, 155, 0.
When we scan documents and then try to look at them to ensure we have it right. We have a problem....
(More)
When we scan documents and then try to look at them to ensure we have it right. We have a problem. File conversion problem. Encoding does not appear to work. We use a AGFA snapscan e 42 scanner. Also we try to get updates, and that seems to be a problem. Can you help me Thanks
