Question about Hoshizaki KM-1600S Stackable Crescent Cuber Ice Maker
NEED TO REPLACE PREFILTER CARTRIDGE AND HOUSING
I HAVE A HOSHIZAKI MODEL 2 KM-630 MAE ICE MACHINE. THE HOUSING FOR THE PREFILTER A MANITOWOC TRI-L #K00173 HAS STARTED SPRAYING WATER AND NEEDS REPLACED. WHERE CAN I FIND A REPLACEMENT FOR THIS PART
    Problem Solver:
  • 16 Answers
Please call your local Distributor heres the link put in your Zip code and it will give you a Dist. in your area that may be able to help.
http://www.hoshizakiamerica.com/techsupport/dist_loc.asp
Posted on Jun 19, 2009
Why isn't my Hoshizaki km 630 mkh ice maker not making any ice?
that could be a number of problems..is it making any beeps or flashing lights on the circuit board? Have you tried to reset the circuit boards reset button with the machine on. ? If the machine seems totally dead then the bin thermostat is most likely the problem..
Aug 02, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Model KM 630 MAE
Look for a stuck float switch. unit fills with water for 1 minute, then the board "looks" at the float to "see" if there is enough water in the unit to run. If float switch is stuck down, it tells the unit there is not enough water and the unit stays in the fill cycle causing the sump to overflow and send water down the drain constantly. Compressor will not run till the board senses that there is enough water to run.
Jun 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
All cycles work except harvest manitowac ice machine
Ice thickness probe on Manitowoc and float switch may be dirty or stuck if hoshi. Manitowoc sometime the thickness probe can get dirty and a film of algae and not sense ice properly but rare
Oct 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
KM-500-MAE Hoshizaki Problem huge cubes, alarm code three beeps
Might need to clean float switch, or water inlet valve bypassing water. Deep clean Hoshizaki.
Sep 30, 2010 | Hoshizaki Commercial Freezer KM-500MAH
KM-500-MAE Problem huge cubes,alarm code 3-beeps
excessive freeze cycle=60 minutes. In almost every case, it's the water valve (sometimes called the fill valve) is leaking water continually into the sump. Turn machine off and see if you can still hear water running into the unit. If so, it the valve leaking. Just replace it.
http://www.hoshizakiamerica.com/manuals/KM-500M_E_serv.pdf
Go to this site and download you copy of the service manual. It has lots of good stuff.. Let me know if I can be of any further help.
Sep 30, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
Jul 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine with constant beeping every 3 seconds
Most likely(50% of the times) Your Ice machine need a real cleaning. not just run clean cycle with ice machine cleaner. every 6 month call HVAC-R guys - machine will last half time longer if u schedule proper maintenance with them. I have seen It all: people try to call "friend", or someone who "knows" how this machines work. Real clean would take up to 3 hours for people who know what they doing. Here is one of my videos, when 3 beeps - long freeze cycle is not common and all others would offer You to get a new Ice Machine. Bill to the owner was 950$, New Machine 3450$ plus labour to install 600$.
Jun 23, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Ice cube cycle time very high
i suspect a defective liquid line or pump down seleonid coil. just make sure you hear the "click" when it starts up if not the selenoid coils could be defective. also verify that the condenser fan is running,because if not you are short-cycling on high head pressure. please contact if you need any additional info
Jun 11, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki KM-1600S Stackable Crescent Cuber Ice Maker Logo
124 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
