Question about GE JVM1440 Microwave Oven
I can not locate my charcoal filter in my GE Spacemaker Profile JMV2070BH02 where is the charcoal filter
  • 864 Answers
Charcoal filter is behind the grille at the top of the oven. Find screws in front or at top of the grille and remove them.  Remove the grille by shifting to one side and pulling forward with the door open.  You should see a slot where the filter is inserted.  Remove old filter and replace with new.  Note which side of old filter is up and position the new one the same way.  The filter sits on tabs at the side and back.   Replace grille and screws.
Posted on Jun 02, 2009
Will not heat. ... Could not replacing the charcoal filter be a problem?
A microwave that fails to work usually needs either a fuse or a magnetron or a capacitor.
Oct 21, 2013 | GE Profile Spacemaker Over-the-Range...
Control panel on GE Profile Spacemaker microwave not working
You are right the control panel is very expensive, you can try the filter to see if you can get it working, but I must admit a new microwave oven sounds appealing.
Jun 25, 2012 | GE SpaceMaker Microwave Ovens
GE PROFILE SPACEMAKER 2 JVM2070SH001 MANUAL HOW DO i REPLACE CHARCOAL FILTER?
That's covered in the owner's manual. If for some reason you don't have yours, you can download GE owner's manuals and installation instructions here.
You can find handy exploded views and order parts (including filters) here.
Jan 10, 2011 | GE Profile Spacemaker Over-the-Range...
Ge profile spacemaker 2.0 model#JVM2070SH001 - HOW TO REPLACE CHARCOAL FILTER.
How to install charcoal filter in ge spacemaker microwave
top of the front grill there are 2 screws. remove those together with the grill. install filter in location underneath.
Dec 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The Charcoal Filter (JX81C) used for non-vented GE Spacemaker over the stove microwave (JVM1540SM2SS) does not fit anywhere (after pulling off the grill).
This of course assumes that your oven has the optional Recirculating Charcoal Filter Kit (part # JX81C available here) already installed.
From the owner's manual here:
Nov 27, 2009 | GE Spacemaker JVM1540 Microwave Oven
How do you change the charcoal filter on the GE Profile spacemaker 2.0
You can download GE owner's manuals and installation instructions here.
You will need the
full model number from the tag on / in the unit.
You can find helpful exploded view diagrams and order parts (such as a charcoal filter) by entering your full model number from the tag on the oven
here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 08, 2009 | GE Profile Spacemaker Over-the-Range...
Changing filter
The grease filter is changed from the bottom of the unit.
The charcoal filter is changed as follows:
To Remove Charcoal Filter
To remove the charcoal filter, disconnect power
at the main fuse or circuit breaker panel or
pull the plug.
Remove the top grille by removing the screws
that hold it in place and sliding the grille to the
left (opening the door makes grille removal
easier). Slide the filter towards the front of the
oven and remove it.
To Install Charcoal Filter
To install a new filter, remove plastic and other
outer wrapping from the new filter.
Insert the filter into the top opening of the oven as
shown. It will rest at an angle on 2 side support tabs
and in front of the right rear tab. Replace the grille
and screws.
Aug 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the charcoal filter?
There is no charcoal filter unless you replaced the standard filter with a carcoal filter. Also, it may have m=been changed to a charcoal filter if the unit was alterd during installation as a re-circulating vent, not vented to the outside via the roof or wall.
The filter (Charcoal or not) is on the bottom of the unit. Put your head under the microwave and look up, there it is.
Apr 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Filter Change
Take off the grill above the door - 2 screws and it is easily found behind the grill
Feb 17, 2009 | GE Profile Spacemaker Over-the-Range...
GE JVM1440 Microwave Oven Logo
388 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
