Question about Brother MFC-7820N All-In-One Laser Printer
How do I add toner to machine? Also, is this copier do color copies?
  • 37 Answers
1 Open the front cover and pull out the
drum unit and toner cartridge assembly.
2 Hold down the lock lever on the left and
pull the toner cartridge out of the drum
unit.
3 Unpack the new toner cartridge. Place
the used toner cartridge into the
aluminum bag and discard it according
to local regulations.
4 Gently rock the toner cartridge from side
to side five or six times to distribute the
toner evenly inside the cartridge.
5 Remove the protective cover.
6 Insert the new toner cartridge in the
drum unit until it clicks into place. If you
put it in properly, the lock lever will lift
automatically.
7 Clean the primary corona wire inside the
drum unit by gently sliding the blue tab
from right to left several times. Return
the blue tab to the Home position (▼)
before reinstalling the drum unit and
8 Install the drum unit and toner cartridge
assembly in the MFC.
9 Close the front cover.
If you need illustration for this, click on the link below and turn to page 112
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Posted on Jun 02, 2009
Why does my kyocera 2026 display an error and says add toner even if I have already added toner?
because your dv unit is not agitating your toner these machines are notorious for this you can take out suspect color dv unit cover the toner hole shake the hell out of the unit smack the bottom a few times put it back in and if that works it will say adding toner it may overtone that color but running multiple copies will eventually clear the excess its best if you wrap the unit in a rag as well as cover the toner hole because toner will leak out when you shake it or replace that color dv unit but they are expensive if you don't know how to remove the dv unit try google or youtube try not to let anything come out when you shake it because there is developer as well as toner in there if you lose too much of that your unit will be worthless it wont ever be able to add enough toner to get add toner message to stop
Apr 08, 2017 | Kyocera 2026 Copier
The machine acts like it's making a copy but nothing comes out. had trouble before but it corrected itself. not this time.
Is the machine just running? Either after turning it on or pressing the copy button? This usually means that the toner is very low and the machine is trying to add toner which it must do before it will actually make the copy. Let it run for a few minutes and see if the toner light comes on. This will look like a small stack of 6 dots. If this light comes on you will need to replace the toner cartridge.
Sep 14, 2010 | Sharp AL 1631 Copier
Ricoh 4220 copier. I replaced toner cartridge and
I suggest removing the toner, and visually inspecting it, make sure the sealing tab has been removed, give it a really good shake, as the toner may have settled in storage. re-insert the cartridge making sure it goes in the right way.
If you can hear a slight 'clicking' noise it's adding toner and pumping it into the developer unit, some machines take 2 minutes, some take 6..
Failing that, lift the platen cover and do a few black copies, so you force the machine to add toner.
Goodluck.
Oct 16, 2009 | Ricoh FT3713 Copier
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
No error message but copier light doesn't come or number of copies doesn't work
let it run eventually the toner lite will come on, sharp copiers will run an extended period trying to add toner to the developer. developer is 70% iron filings and 30% toner as it uses the toner it cycles more in to stay at the proper level.
Apr 14, 2009 | Office Equipment & Supplies
How do you change the toner in a Minolta Dialta copy machine?
Check the back of the machine see if the sticker is still on it. Model number should be there. As for toner carefully remove the toner bottle turn the machine off wait ten seconds turn the machine on do not put the bottle of toner in until the waning comes on to tell you to add toner. The word "up" on the toner bottle should be visible onthe tup when you install it, so should the hole. Theres a small nub that will lock int place when installing it.
Apr 01, 2009 | Minolta DiALTA Di183 Copier
Will not reset for next copy
Sounds as if it is low on toner.When they run low, the motor will continue to run trying to add more toner.The toner add system is a glorified flour sifter.Eventually it will set the add toner on.Good Luck
Mar 24, 2009 | Canon NP 7130 Black and White Copier
The add toner light stays on with a new toner cartridge
Yes, the machine will only make single copies if the toner light is on. Was the toner cart genuine Copystar? Or perhaps Kyocera cart? The machine is made by Kyocera and marketed under both name brands, however, the toner carts are different for both machines. I have seen many times that aftermarket carts will not always work properly.
Jan 06, 2009 | Copystar CS-1510 Copier
Ricoh ft3713 toner overflow
remove the toner bottle, open the back cover and look for the small DIP Switch turn on and off, by doing this you are forcing the machine to come out from add toner condition. Then you do 20 sky shoot.
Oct 24, 2008 | Ricoh FT3713 Copier
Brother MFC-7820N All-In-One Laser Printer Logo
95 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
