Question about HP Pavilion dv2500t Notebook
Hp dv2500 graphic problem
Hi it's regarding hp dv 2500 it shows 6 pictures of the same picture i mean every image instead of showing once shows 6 times i wonder if i change the grahic card wil this be sorted or i am going to waste money by doing that as i cant refund money on graphic card once open thanks
zak
  • Chris
    Chris May 11, 2010
    Some more detail is required,
    First is this the HP laptop you selected above?
    Second please clarify 6 times, are you referring to the desktop images, importing photos from a camera or opening images in a particular program? if the latter, what program?
    Thanks,
    Chris
  • 197 Answers
Update your video card. To update download the latest driver of your video card from HP site. Copy and paste the link provided below to your URL and it will lead you to HP Pav dv2500t drivers. Choose the OS you are using, look for the video driver, download it then install to your machine.
link:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3369421&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Posted on Jun 04, 2009
How do I export image as jpg format for the web?
hi,
just go to file=> save for web and devices and there select jpeg as output format and the quality...
cheers
mich
Jan 07, 2015 | Adobe Photoshop 7.0 for PC
Bad picture on Samsung HP-R5052 50 in. Plasma HDTV
Hi there!
I suggest changing the screen , it is getting worn out
peace.
May 18, 2017 | Samsung HP-R5052 50 in. Plasma HDTV
Head cleaner
That rather depends on how well used the machine is. It also depends if you use tapes with known problems or old ones. The best way to judge it is when you start to see sparkles on the pictures. That's a sign to clean. If the machine is not used a lot I would say every 3 months. VCR's kept in a room where people smoke should be cleaned however at least once a month. Some VCR's have a small roller that cleans the head. However that can become grubby, so that needs cleaning or replacing after a while.
Don't forget the mechanism tape pathway can pick up dirt. That should really be cleaned every 6 months at least.
Apr 07, 2014 | Panasonic AG-DV2500 DV/Mini DV VCR
Play back screen does not show any image it is just showing a blank white back ground
A component called CCD IMAGER is faulty and needs replacement, Basically the component works as an eye to view the image when it start malfunctioning screen and viewfinder does not show image. The detail of said part is given below:
Part No. Description
8-753-244-71 ICX611NKF-13 (CCD IMAGER)(HC51E/HC52E/HC53E/HC54E)
For convenience area is marked with red circle in the picture below:
Thanks
May 19, 2011 | Sony DCR-HC52E Mini DV Camcorder
I dont have picture for recording
Welcome to Fixyah,
If yo can't see any picture please check your video cable connection.
>checked if the video cable is properly connected from dazzle to your camcorder.
>if you connect you camcorder,vhs,VCR using S-video then go ahead and click on option on step number 1 click on video input and then click on S-Video click also VHS input and then click okay.
>If RCA the same thing click on option then video input and then select Composite.
>Turn your camcorder,VHS,VCR on and then hit played button.
>checked your preview screen if the video image is now showing, If showing then start recording.
Regards.
Mar 11, 2010 | Pinnacle Dazzle DVD Recorder
Hi there When I shoot in 16x9 widescreen with my Canon XL1 the viewfinder shows the same image as when shooting in 4x3. Can this be adjusted. Regards John
It is not showing the same image, it is showing the 16x9 squished down to the 4x3 aspect ratio. I thought I had the same thing at first too. But to check & make sure set up a shot of something square in one or the other shooting ratios. Then go into the menu & set it up on the 16x9 on/off. To make it easier to see the picture hook up to a monitor to see the picture without squinting through the eye piece. Now while you are watching the picture switch the 16x9 on & off on the camera. If you started in 16x9 the square will lengthen from side to side in 4x3, while the square in 4x3 will become squished on the sides. If you can't tell, take a piece of tape [removable tape that is] and make the sides of the box before & after you change the aspect ratio.
Apr 29, 2009 | Canon XL1S PAL Mini DV Digital Camcorder
Shows as widescreen instead of normal view
try using the tv remote to change the screen size and keep changing it until you find the correct size
Oct 21, 2007 | Pioneer DV-525
DSC T20 poor image problem
If you took the images at 8MP or 5MP settings, then normally you have a high resolution picture, was the picture clear at the cameras LCD monitor? As you said its like low res in your PC, please check the image file size 8MP resolution will be approx. 3Mb size, if its about that figure, then the problem is in the camera, if the file size is about 500K maybe its in the camera settings, PC cant affect resolution, unless you only have VGA card and monitor, hope this will help, thanks
Sep 12, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
HP Pavilion dv2500t Notebook Logo
378 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
